Old 09-18-2007, 10:49 AM   #1
wibilly
wibilly's Avatar
dome and cargo light problems
i can't seem to get my dome and cargo lights to work. i have power bulb is good i have a ground with light switch or door switches but no ground at light. when i add a dround at light fixture with a test jumper it blows the fuse any ideas as to what might be the problem
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-18-2007, 11:05 AM   #2
cwilli84
1FINE69
cwilli84's Avatar
Re: dome and cargo light problems
Check the wires along the drivers door sill (under sill plate for a short). I had a similar problem and found out a screw had nicked a wire and allowed moisture to corrode the wire for the light.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 09-18-2007, 08:56 PM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
It would seem to me that if you blow a fuse by grounding the light fixture,then the fixture itself has a short circuit.Take it out and fix or replace it.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 09-18-2007, 09:13 PM   #4
wibilly
wibilly's Avatar
got them fixed.although wires tested good for continuity the ground was was nearly broke and would not complete the circut as for an aditional ground blowing the fuse, in the series of plugs from the fues panel for the door switches,cargo light and the one to the dome light, the one to the dome lighthad the white and orange wires reversed in the plug so when i added the ground at the dome light it created a direct short{all these harnesses came from different trucks}
