Old 09-18-2007, 11:12 AM   #1
panhandler62
Java Mechanic
panhandler62's Avatar
Whoa her up!
I couldn't find anything resembling a clear FAQ on this but would certainly accept a link to one if someone knows of one.. anywho --
I have a 68 C-20. I want to retain the 8 lug wheels (cuz I like heavy duty!) but would like to upgrade to disks in front.
It seems like the best way to get this done is to canibalize a beater that has the parts I need but since that means 71/72 trucks .. and common they aren't -- what else will either fit or fit with relatively minor mods? I'm betting that a hulk of an 82 chevy is going to be an eiaseer catch in a bone yard than a 72 C-20.
Please bear in mind -- This is my first real custom project and budget could be an issue, so cool as a Vette front end or dropmember based suspension is -- those are out of my $$$ range and level of experiance.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-20-2007, 08:06 AM   #2
panhandler62
Java Mechanic
Re: Whoa her up!
Hmmm.. is this a bad question to ask or is it just a case that no one has an answer? :P
I guess I can find a late model to canibalize and hope for the best.. was just hoping to have a better idea of what to look for in the bone yards.
Keith
Old 09-20-2007, 08:36 AM   #3
chevy72blu
chevy72blu's Avatar
Re: Whoa her up!
I dont know for sure, but I imagine that there is an 8 lug out of a 73+ with disks that will fit... But why not just go with a 5 lug? There are many heavy duty options availible for what most people build and are much easier to find.
I have 73+ front a arms, drop member, and rear in my 72.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 09-20-2007, 10:58 AM   #4
panhandler62
Java Mechanic
Re: Whoa her up!
I could go with 5 lugs but that means replacing more parts.. because I'm not about to run an 8 lug rear and 5 lug front.
I'll have 4 useless wheels afterwards.. but I suppose someone might want them. lol
I think the fitment question still applies if I go that rout .. waht (beyond the obvious 71/71 trucks) fit a 68?
Keith
Old 09-20-2007, 11:02 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Whoa her up!
The 73-87 front crossmember is a direct bolt in (sorta). From what I understand there are a couple of holes that don't line up so a little drilling might be required.
With that said, finding a donor 73-87 C-20 should be simple and cheap. You might consider what else you need, and try for a truck that you can steal other parts as well....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-20-2007, 11:08 AM   #6
panhandler62
Java Mechanic
Re: Whoa her up!
I found exactly what I need once already... but it's in Mo and I'm in Wv ...
Keith
Old 09-20-2007, 09:44 PM   #7
crazy longhorn
Fabricate till you "puke"
Re: Whoa her up!
On your 3/4 ton, the 71-87 s use the same ball joints ect.....also the 3/4 tons still had the steel bushings in the a arms, unlike the 1/2 tons going rubber bushed in 73. Probably the easiest swap would be the complete crossmember (as already mentioned), but you CAN just swap the balljoints, tierods,spindles & all steer linkage & retain your stock a arms. best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-21-2007, 12:38 PM   #8
panhandler62
Java Mechanic
Re: Whoa her up!
Great... thanks for the info.
Keith
