PITbut
Add on compressor tank? Anyone done it?
I have a new 25 gallon craftsmen compressor. I want to ADD an additional tank so i dont have to keep starting and stopping because of losing air pressure.. Its the beefy construction grade compressor so im not worried about it handling it. Anyone ever done this and added an additional storage tank i guess you could say???
Old Skool Club
![]() Join Date: Jun 2001
Re: Add on compressor tank? Anyone done it?
In my previous employment, we had air in the plant supplied by compressors in our power house. When it got to a specific building, it was fed to a doubler. From the doubler, it went to another tank. It didn't double the pressure of the air (don't know why it was called a doubler) but it did serve to increase the amount of air we had available to us....and we used a LOT of air.
Seems that so much of the time, the air we need limits our ability to perform tasks that have higher SCFM requirements than our compressors will create. If nothing else, the doubler got around that limitation. Certainly, an additional tank, with a one-way checkvalve between them, isn't going to hurt your system. But installing a doubler between the tanks will help, too.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Is it a single or two stage comp. (is the motor and comp. a one peice or seperate with belts) If you have a single don't do it cause it will take forever to recover, the comp is usually sized for the tank. Ive added them on a 60 gal with a 2 stage comp and a 7hp peak 2hp running motor, but there more of a 100% duty cycle than the single stages, it will run longer and you might not get that much more out of it than you already have. If the comp. is already not keeping up while your using a tool an extra tank isn't going to help unless you want to stop while its filling up, mine will shut off while Im using a die grinder or impact continiously, so extra air in the tank is not of concern.
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
The more air is only going to give you more instantanious air not continious, my dads shop has 2 turbine compressors that sound like jet engines firing up but they can supply 25 guys running tools with no tank at all but the tank is there for the instananious drain of not using air to all of a sudden boom 5 guys fire there tools at once. Basically the CFM rating on the comp is more than the tools use combined, thats more of what you need to be concerned with, what your tool is using and what your comp. pumps
#5 | |
#6 | |
PITbut
http://www.sears.com/shc/s/p_10153_1...+%26+Inflators Thats why i have now. I had an air sander that the compressor couldnt keep running worth a ****.. Well, i want to get this sand blaster from harbor freight, but dont know if its going to work.. Heres the link to the blaster. http://www.harborfreight.com/cpi/cta...emnumber=34202 Any other info for me on what i can do with what i have? |
adding another tank isn't going to cut down on the amount of time the compressor runs ... it's actually gonna increase it.
it's like saying that because you add a second gas tank that your mileage will pick up ... it won't ... same mileage ... just more miles between fill ups but now the fill ups take twice as long. |
#8 | |
PITbut
Adding more volume to the air storage and getting the larger volume pressurized before staring the task will allow you to use more air before the pressure drops to the level where the comp comes back on (slower pressure drop due to larger volume) which may help you get through some shorter duration tasks without low air pressure condition. The comp will have to work just as hard, but longer in time in order to get the larger volume to the shut-off psi. In one shop where I needed to run air pipe the length of the room (with three outlest along the long wall) , and instead of a second tank, I installed 6" Sched 40 pipe to get volume (had to do the piping anyway) which achieved similar effect to a second tank of similar volume.
Hope this helps. CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
Old Skool Club
A compressor can do no more than it was designed to do. If the one you have isn't big enough, you'll know it. At that point, you have two choices....
My uncle took the compressor from a C-65 Chevy and used it to supply the air he needed in his shop. His compressor was an old Curtis unit that dated from the 40s's (at the latest). When the original Curtis compressor was no longer able to be rebuilt, he scabbed onto the truck compressor. He had all the air he needed. I don't know the SCFM rating of that unit, but he used air for all his needs, but no painting/sandblasting.
#11 | |
Do you have it hooked up to 110 or 220 if its hooked to 110 it wont perform as well. What did you pay for it mine was on sale for 399.99 at the local depot
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 09-19-2007 at 12:59 PM. |
#13 | |
Here's an example link: http://www.pavementsucks.com/tech/yorkcomp.php
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
