Old 09-18-2007, 02:35 PM   #1
chevy72blu
chevy72blu's Avatar
Lets talk performance drag suspension conversions. Air ride a poss.?
Ok, heres what I got.
72 SWB (Z'd the frame, converted from a 3/4 long box to a 5 lug 1/2ton SWB).
73-87 front member. 73-87 A arms up front ( to convert to disks), 73-87 12 bolt in the rear with about 2-3 original 73-87 leafs (pulled the over-loads out to drop the back and take care of the crazy rake it sat at.
Heres how she sat when I first finished the suspension work:
She stood like a damn cockroach.
And here with the over-loads pulled (like she is today)
(Sorry I dont have a side-only profile of it)
Meant to say... this is how much front travel I currently have (This was under about 360 (at launch) ft. lbs of torque supplied by an SBC)
As you can see, im only getting about 4" of front end pickup with the current set up, and zero drop in the rear (no weight in the back.. and their may have still been the over-load springs when the pic was taken)
Now, there is a fresh 500+ hp 496 between her fenders that has yet to be fired. Its a street strip truck which main purpose is on the track with some cruising. My main goal is safety and track performance on 14.50 inch DOT slicks. My driveline is stout, but im on stock suspension and stock brakes.
I have NO idea what to do with the rear. Convert it to a 4 link with coils? I have no idea how to build this, but a good buddy of mine did his own custom 4 link in his Jeep recently. Monoleafs and Cal-tracs a better option? Budget is a big issue here, but im taking my time and making it right. I want to put adjustable drag shocks on all 4 corners. Are air bags a possibility with this build? (Never used them... but Id love to have my truck sitting on air.) Im throwing a summit fuel cell in the bed (as well as a nitrous tank) to help with weight displacement. I want this thing to squat hard on the green light. Being able to open the nitrous bottle from the line and get a couple pictures picking some tire would be AWSOME (though infrequent.. as my TH350 is built tough, but its life span is limited at best).
Up front, I would like to go to tubular A arms and possibly one of those trick drop members. But, I dont have much of a desire to lay the frame in it, so that would most likely be a waste. I want to (at the very least) throw some 2" drop coils in up front to give it the stance I want. Can 90/10 or close drag shocks be used with drop coils? Any recommendations on both parts?
This much power needs big stopping power also. Right now shes all stock in the brake dept. Im convering it to hydroboost due to the 108* LSA cam isnt gonna make a ton of vaccuum, and Ive heard hydroboost is awsome. I'd like to put some good size cross drilled/slotted rotors up front with a solid 2 piston caliper. Any recommendations on (cheaply) obtaining these parts would be awsome. Eventually im going to convert the rear to disks, but the drums should be fine- tuned well with heavy duty equipment up front. (Or maybe not? you tell me.)
Im brand new to suspensions to a few lay terms would be nice (I have no idea what gusseting is, for instance.)
I appreciate any feedback! Thanks!
Let me know if more info is needed in any area
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 09-19-2007, 06:36 PM   #2
AirMale
AirMale's Avatar
Re: Lets talk performance drag suspension conversions. Air ride a poss.?
Ca Chassis Works Has A Great 4 Link
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 09-20-2007, 06:19 AM   #3
chevy72blu
chevy72blu's Avatar
Thanks. Im gonna build one, I think.
How much power are you makin?
RIP EastSideLowLife
Old 09-20-2007, 10:47 AM   #4
AirMale
AirMale's Avatar
Somewhere between 620-650hp
86 SWB 9.0 LITER
Old 09-20-2007, 01:31 PM   #5
revn67
revn67's Avatar
you can also go with coilovers on a dropmember i believe if you don't want to layframe...and you'll have upgraded steering while your at it
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 09-21-2007, 01:33 PM   #6
chevy72blu
chevy72blu's Avatar
I should produce around 700 on nitrous... I was just hoping to go better than 12 and a half's. How hard were you slipping? what tire?
RIP EastSideLowLife
Old 09-21-2007, 02:50 PM   #7
SCOTI
SCOTI's Avatar
I have no personal knowledge of this but I've read that many tracks won't allow air ride equipped vehicles down the track (helper bags are ok). It would be worth it to verify @ the track where you plan to race.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-21-2007, 07:33 PM   #8
AirMale
AirMale's Avatar
I haven't been to the track with the 4 link yet. The 12.50 was with the leaf springs and a hidious 2.02 60ft. time.
86 SWB 9.0 LITER
Old 09-24-2007, 12:18 PM   #9
jamis
F.A.S.T. president
jamis's Avatar
The position of that rod end on the panhard bar seems odd. I would think it should be turned 90 degs so to get full swivel of the joint. I would think it would bind in that position as the suspension moves up and down.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 09-24-2007, 12:45 PM   #10
AirMale
AirMale's Avatar
Works for me. Chris Alston designed it for high HP pro street cars and trucks.
86 SWB 9.0 LITER
Old 09-24-2007, 05:25 PM   #11
Custom 68
Custom 68's Avatar
What type of pinion angle do you guys shoot for? I am stock with 4 inch lowering springs and seems like my rearend is pointing upward too much. I have the measurements but not here but it seems like it is upward about 7 -8 degrees?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-25-2007, 11:08 AM   #12
chevy72blu
chevy72blu's Avatar
4-5 degrees is what you want, if memory serves. Any driveline shop can roll the spring perches for you to correct this. Eventually you will ruin your gears
RIP EastSideLowLife
