Old 09-18-2007, 03:45 PM   #1
53sparks
big block sparks plugs
I have a 68 gmc with a 396 (which i think is original motor) it had r44xls plugs, i put a hei in it was going to change to the r45ts but they dont have a long enough throat or enough threads, should i stay with the 44xls and regap to 45 or is there another plug i should be using thanks Ron
53sparks is offline   Reply With Quote
Old 09-18-2007, 03:51 PM   #2
airdale94
airdale94's Avatar
Re: big block sparks plugs
Could you use, say a later model 454 plug? I'm not sure but don't HEI's gap to .060" ?
airdale94 is offline   Reply With Quote
Old 09-18-2007, 03:59 PM   #3
kwmech
you can use the same plugs
Old 09-18-2007, 04:03 PM   #4
53sparks
the later model plugs have shorter threads and dont even thread in the holes, why is this
Old 09-18-2007, 04:06 PM   #5
steveshow
steveshow's Avatar
use the stock pn plugs and regap to at least .045
steveshow is offline   Reply With Quote
Old 09-18-2007, 04:49 PM   #6
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I understand the GM dealers and some after market are now selling a simple part nnumber for the AC delco plugs 1-6 changes the heat range.
I understand the #4 plug is an ideal street plug for the big block.
All that being said I just bought the R44XLS plugs for mine and gapped them at 45
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 09-18-2007, 07:39 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've been told to go with a R45TS plug, it's a little longer and helps resist fouling on older engines.
This was for a 72 402, iupdated with HEI
Old 09-18-2007, 11:09 PM   #8
53sparks
longhorn man, i tried the R45TS they dont have enough threads to even screw in, but it sounds like i can go with the R44XLS, are the older big block heads casted different than the newer big block heads? Thanks for all the input Ron
Old 09-18-2007, 11:29 PM   #9
Longhorn Man
I have no idea. Thiw will be my first big block chevy
Old 09-19-2007, 07:20 AM   #10
arkracing
Weekend Warrior
I ran into the same problem recently.
Had to go with the R43XLS's which is 1 step colder than the R44XLS's (I did this because my motor is pretty built) If you have a stock motor the R44XLS will work.
Just gap to .045 - that's what I did, and I have an HEI
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
