Old 09-18-2007, 09:18 PM   #1
drummin89
drummin89's Avatar
bear claw latch install
i have a 52 3/4 ton 5 window that im working on doing some minor/slightly major modifications like adding power windows and door poppers. i just recently purchased a bear claw latch kit and door popper kit off ebay and i was wondering if someone could either guide me through the process or post an article of installing bear claw latches. if someone has done the modification of putting the latch in the door jamb and the striker bolt in the door i would much appreciate some shared knowledge as that is what im looking at doing.
this is what i bought
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
also looking at buying this
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
thanks
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 09-18-2007, 10:15 PM   #2
sinister53
Re: bear claw latch install
installing the bear claw latches are a very easy process,you do need some welding skills,the latch in the door jamb is a good choice as the pillar is the perfect dimension ,your kit should have come with a plate to weld in,so you should be able to use this as a template to cut the pillar and then weld the piece in,if you look on this page under looking for comments,ther is 1 pic of mine done,and if you like i can post some of the process of putting in.good luck.
sinister53 is offline   Reply With Quote
Old 09-18-2007, 11:32 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Someone just did an install on an AD truck. Do a search on bear claw
dwcsr is offline   Reply With Quote
Old 09-18-2007, 11:34 PM   #4
Houston54
I installed bear claws on the doors of my 54 last year. Here is how I did it but I kept the original handles. This process would probably adapt to your poppers also.
http://www.picturetrail.com/gallery/...64&uid=2902753
Houston54 is offline   Reply With Quote
Old 09-19-2007, 05:53 PM   #5
Daniel U
Daniel U's Avatar
Wow, that's a very nice "step-by-step" instructional. Thanks
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 09-23-2007, 12:21 AM   #6
solidaxel
solidaxel's Avatar
I have that same E/window kit and it is OK, but I am going to use a different one on my 53 project.
I like the ones that have the motor seperate from the trac as the bottom of the door gets VERY narrow and it is hard to aline
the track with the glass as there can be NO binding as the electric motors on this kit is a bit weak especially in the winter!
I am going to opt for a better kit with the motor seperate from the track attached by the drive cable.
The kits are straight forward as they are anchored to the door and go up and down, but they must be straight!!
I did see some interesting conduit on here by using a bit of brake line attached to the bottom hinge, I don't remember whose idea that was but it will work great.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
