Old 09-18-2007, 09:22 PM   #1
jorgensensc
jorgensensc's Avatar
Just Curious....
Can you Hook a 250 or 292 six cylinder up to a t5 5speed out of a s10 pickup? I already have the tranny from another project that never happened and I'm about to inherit a 6 cylinder out of a '69 truck, although I'm not sure yet what displacement it is. I thought it might be fun to rebuild the six and hook it to the 5 speed and see what I could put it in. Just looking for something interesting. Do they mount up at all??
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-18-2007, 11:58 PM   #2
jorgensensc
Re: Just Curious....
Ttt.
Old 09-19-2007, 01:42 AM   #3
72armyswbtruck
72armyswbtruck's Avatar
I suppose anything is possible with an adapter plate
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-19-2007, 01:50 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Shawn
Yes.
It requires a bit more time and modifications along with an old Vega clutch kit, bit it can be done with off the shelf parts. The drawback is that the gearing in the S-10's aren't very good, specifically 1st gear. They were mostly 3.5:1 on up to 4.03:1 1st gears depending on the engine it was mated to, which isn't very usable.
Oh btw, no adaptor plate is needed. However, many go this route instead of doing a few simple mods.
I'm going to work on a write up which will include info on the S-10 T-5 swap.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
