BlahBlahBlah
Pictures for Botietruck
The bracket is just laying on top of the engine. I have no idea where it supposed to bolt up, I can look at a manual if you don't have one. It has a very large wire bundle attached to it. The bundle disappears down behind the block and over the top of the trans to the passenger side of the trans.
You can see where the overdrive pull cable comes out of the firewall. There is also a wire bundle that comes out above it. This looks like it runs down below and may be a part of the wiring for the OD. Im not sure though, none of the OD is hooked up. If you need more pics let me know. Ill have to pull it outside where I can get to it better. |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
Re: Pictures for Botietruck
Mark, Thanks for the pics. That helps alot!!
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
