09-18-2007, 11:08 PM | #1 |
Cab repair panels, what do i need?
I'm taking my truck apart slowly but surely, and I got the carpet out and yeah... considering this is the only place there is rust its not too bad but thats alot of work, what panels would i need? links would be preferable.
thanks PASSENGER SIDE( looks like surface rust, should be fine to grind it down i think) REST ARE DRIVERS SIDE |
09-19-2007, 01:10 AM | #2 |
Re: Cab repair panels, what do i need?
first thing you need are ebfabman's videos www.ebfabman.com
For your pass side its hard to tell from the pics, could be surface rust but it looks rough. Only thing you show is the floor pan so hard to judge on what it'll need. Driver's side you'll be after front floor panel, outer rocker and kick panel. Depending on the damage and your skill you'll probably need the rear floor panel as well. Looks like some rust on the lower front of the door so you may need an outer and inner panel for that, again pics don't really show. The condition of the lower A and B pillars isn't seen but odds are good they'll need replacing as well. I don't think anyone makes a patch for the top of your cab but that looks like a fairly easy fix. How are your cab corners? |
09-19-2007, 08:02 PM | #3 |
cab corners just look like surface rust, im getting the cab media blasted soon so im sure that all will show. unless i should repair the panels before i do the media blasting?
09-19-2007, 11:58 PM | #4 |
media blasting first will show all your trouble spots and make it a lot nicer to work on
09-20-2007, 01:05 AM | #5 |
wont make things worse? i mean i know i gotta cut most of the rust out anyway, or sand it down, but it would worsen things that are already bad?
09-20-2007, 01:16 AM | #6 |
I think the blasting is the only way to go it will save you more time by showing you the true areas that need attention with no suprises. In my opinion its the only way to get rid of all the cancer before you start the build and to make sure its gone for good.
09-20-2007, 10:16 AM | #7 |
How do the cab mounts look?
09-20-2007, 08:39 PM | #8 |
not sure yet, stil trying to get the bed apart, so once i do and get more room at the side of my house ill check. from the interior though, the middle of the cab is spotless, no rust whatsoever.
09-21-2007, 01:05 AM | #9 | |
Good call on the mounts though Bucky71, I forgot all about them. |
09-22-2007, 06:12 PM | #10 |
so i took some more photos, here they are
drivers side looking forward drivers side rear cab corner drivers side again drivers side floor passenger side floor, there is a hole right through |
