Old 09-19-2007, 10:54 AM   #1
85X3
Air Bags with DJM Tubular Lowers
Has anybody installed an air bag system with DJM 3" LCA's? If so, any modifications needed? Also, are there any rack & pinion kits available without changing the crossmember? This site is the best source of information on the net, (for our trucks) so I'll ask the members for their input. Thanks in advance for any info submitted.
85X3 is offline   Reply With Quote
Old 09-19-2007, 04:01 PM   #2
edflores
Re: Air Bags with DJM Tubular Lowers
you probably have to plate the lowers and then drill a hole to center and mount the bag. you should ask in the suspension section.
edflores is offline   Reply With Quote
Old 09-19-2007, 08:27 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I have done it. I completely cut off the lower buckets and just put a flat plate across it. If I had it to do over again I would probably put a litle bit of an angle on it for better bag alignment at lower ride heights, but I have had zero issues with my set up.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
