Old 09-19-2007, 12:45 PM   #1
satin64
satin64's Avatar
bench interchange help
will a 67-72 bench seat bolt in to my 64?or is there some mods that need to be done?what years fit and any mods required?i want to get the buckets out and go with a bench.thanks
satin64 is offline   Reply With Quote
Old 09-19-2007, 01:11 PM   #2
slepysal
slepysal's Avatar
Re: bench interchange help
you might have to drill a few holes that should be it.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-19-2007, 11:14 PM   #3
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
67-72 Bench will bolt in, but you need to shim the front. On 60-66 trucks the floor pan is flat where the seat bolts. So the angle of the seat is in the mounts. On a 67-72 the mounts are shorter on the front because the floor has a ridge that the seat bolts too. unfortunately the mounts do not interchange between the two seats.
65StreetCruiser is offline   Reply With Quote
Old 09-20-2007, 01:05 AM   #4
satin64
satin64's Avatar
cool thanks.that helps since ive found some 67-72 seats on craigslist.
