Old 09-19-2007, 09:17 PM   #1
Primered_69
Primered_69's Avatar
What size brake lines?
What size (ex. 3/8 or ???) do I need to get?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 09-19-2007, 10:09 PM   #2
xshadow
Re: What size brake lines?
What brake lines do you need? Mine had two differant sizes. According to my reciept 3/16 and 1/4
I just took a brake line off to bring with me to the parts store, and then just matched them up.
xshadow is offline   Reply With Quote
Old 09-19-2007, 10:22 PM   #3
xshadow
My c/20 had (i'm going by the sizes on my reciept)
1/4 for all of the rear brakes and 3/16 for the front
On my K/10 it has the 3/16 from the rear cylinders to the hose. (one end has to have a larger screw end for it to screw into the box for the hose ) I used an adapter. from the hose it had 1/4 all the way to the prop valve. for the front I'm pretty sure it had the 1/4 from the pro. valve to a block and 3/16 from the block going to each front brake hose.
Note... for the rear brakes the line comming from the prop. valve has a larger end that screws into the prop. valve.
Old 09-19-2007, 10:24 PM   #4
xshadow
but I could be wrong.....
