I could use some wiring schematic info
I've posted an alternators (mopars) question in the electrical section - not getting much visibility so I'm trying to paste a link here - if any of you all wouldn't mind taking a quick gander at it, I'd much appreciate it.... here goes.....
http://67-72chevytrucks.com/vboard/s...d.php?t=258900
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: I could use some wiring schematic info
a pic
Check to make sure the voltage regulator is grounded to the same frame the battery & engine are or it wont work properly.
![]() Join Date: Feb 2004
What difference does it make as long as it is grounded?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
