The LuvShack Garage
Ok let me have it, I have the kit, but on the fence about installing it.
Right now aired out sitting on the rear snubbers I have 1/2" between the frame rails & the rear axle. Obviously this would let me get down a few more inches before the punk'n hits the bed floor. I'm only using 17's at the moment, but long term want to go either 18/20 or 20/22. I just finally got the 15's off week before last so I am sorta stylin ![]() My question is if I am going bigger down the road, hence more tuck, what do I gain from installing the C-notch other than it aired out flat on the ground look? Keep in mind I'm aproaching 40ish so I want it to have the ability to drive aired out incase of a highway emergency ![]() Here is the 15" pic, center of fenders was 25" F and 27.5" R, now it is 25" F and 25.5" R with the 17's but I can't get new pic's just yet.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: Aug 2005
Re: C-Notch (Pros and Cons)
You get the ability to RIDE at that height instead of just being parked. You will still be able to set up bumpstops that allow you to remain mobile when aired out. With 20s/22s you will need to start looking at making more room ie. inner fender/tub mods.
#3 | |
The LuvShack Garage
![]() PS - I was hoping you would chime in since I consider you a Pro ![]()
A guy with a truck
Lowers your ride height and will allow a larger diameter wheel/tire without raising your ride height. Just do it- it's not like you're hacking the thing up- it's a bolt-in kit from CPP I assume?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
The LuvShack Garage
I believe so, it was another toy included in my package
WTB this ad
Craig are you going to clearance the bed floor or let it self clearance?
If it was me I'd settle for it's current height as opposed to cutting and chopping a original 2wd...that's my 2 cents...
#8 | |
See Ten has a good point though. Might as well accept that you need a little bubble in the floor if you're going to notch it. |
The LuvShack Garage
Hmmmm, ok that's more to ponder over, let me think on this
