09-20-2007, 05:31 PM | #1 |
Junior Member
72 big block motor mount cups
does anyone have a set of 72 big block motor mount cups that they could measure the distance between the red lines like in the pic for me.I need to know the distance between the block mount surface and the center line of the bolt hole.Thanks in advance
Mike |
09-20-2007, 08:34 PM | #2 |
Junior Member
Re: 72 big block motor mount cups
anyone????? TTT
09-20-2007, 10:00 PM | #3 |
2 1/4" center of bolt hole to where it sits against block as per your red lines.
1972 bbc c10 mounts bob
I BELIEVE IN JOHN 3:16 |
09-20-2007, 10:54 PM | #4 |
Junior Member
Thanks, I'm having problems with header fit.Me and friend put his together a few months ago with no issues.Now trying to put mine together with same headers and same type 72 only bbc mounts and mine are not fitting.Every part number on both projects are the same except the clamshell mounts so I was hoping that was were the problem is. thanks for the info
