Old 09-20-2007, 05:51 PM   #1
MyakkaJeff
Junior Member
Can't get guage lights to work
Hey Guys, Hope you can help. I've replaced the fuse and checked the bulbs but no lights when headlight switch is on. I noticed a empty terminal marked cluster feed. Is this the problem? Also, I have a black wire coming from the ignition switch with a female spade connection on it that isn't connected to anything. Where does this wire go? Maybe to that empty terminal? Thanks.
'63 C10 lwb flatbed
'66 C10 lwb stepside
'68 C10 lwb stepside (parts)
'68 C10 lwb fleetside (17 yr old son's ongoing project)
'03 HUMMER H2 (wife's)
'06 3500 flatbed liftgate (My work truck)
MyakkaJeff is offline   Reply With Quote
Old 09-20-2007, 07:47 PM   #2
MyakkaJeff
Junior Member
Re: Can't get guage lights to work
Nobody?
'63 C10 lwb flatbed
Old 09-20-2007, 08:32 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
is the rheostat turned up?
do the tail lights work? (same circuit)
have you checked the bulbs?
Old 09-20-2007, 09:08 PM   #4
MyakkaJeff
Junior Member
Yes,Yes, and Yes. Thanks Longhorn Man. Would you know where the black wire from ign switch goes? Or what plugs into cluster feed port on fuse panel? Thanks, Jeff.
'63 C10 lwb flatbed
Old 09-20-2007, 09:10 PM   #5
MyakkaJeff
Junior Member
P.S. This is a Chevy 68 with a 283 and 3 on the tree.
'63 C10 lwb flatbed
Old 09-20-2007, 09:27 PM   #6
Longhorn Man
I don't know of a pigtail hanging off the ignition switch. I just chopped one out of a 68 GMC for GMCJunkie's son last mo nth, and all wires went to the harness. However, i *think* that would be a ground of some sorts... regardless, it would have absolutly no effect on the laghts.
The terminal on the fuse box is for add on stuff that you would want controlled with the dash lights, or for 69 and up, the light in the tilt column.
Old 09-20-2007, 09:41 PM   #7
jhow66
jhow66's Avatar
Grey wire from light switch to gauge panel-check to see if it has power with light switch on. If not and parking lights work, test with another switch.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-20-2007, 10:08 PM   #8
airdale94
airdale94's Avatar
You might check the printed cicuit on back of the gauge cluster for breaks. My experience it's usually a gauge circuit that gets blown. Also where your plug goes in sometimes the copper can peel back from the laminate and not make contact with one of the terminals.
airdale94 is offline   Reply With Quote
