New Board Member, New Jimmy
Hey all,
I've been lurking here for a while, I've finally pulled the trigger and got on the board... ![]() Just picked up my first Jimmy. It is an all original rig, a 72 with under 60K on the clock. The first owner ran this thing for 10 years, then parked it after his trans let go, it's been quietly rotting away ever since... It needs a lot.. rocker boxes are shot, rear quarters as well as both door bottoms are trash, the front is okay, just a little screwed up... it has a good frame, roof and windshield frame, i'll need to reseal everything and go through the driveline. The plan.. return this to stock form. I have ordered the bulk of the sheet metal needed to whip the rockers back into shape, and will tackle that repair while the body sits on the chassis. Then i'll start on the quarters, and do the door bottoms. I figure doing it this way will save space in the shop, I'll only have the body off the frame for a short while, (i'll be sure to add bracing to the door frames). Any thougths? Am i right to try to build the bulk of this thing while on the frame? ![]() I should have the sheetmetal i ordered by the end of next week, I'll try to get pictures of my progress and upload them. I hope to get the front clip off by saturday as well as the engine / trans and t'fer case out. |
Re: New Board Member, New Jimmy
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
welcome from about 30 minutes south of you
Old School, New Style
Welcome, welcome, welcome fellow 72 Jimmy owner!
NOW POST SOME PICS! (please)
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
The masses are getting restless already, I hope you have a camera or it could get ugly
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#7 | |
Can't wait to retire!!
Welcome from Michigan!
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
Got it... Pics...I'll try to get some up tomorow once i get it on the lift...
I managed to get the front clip off tonight, the bulk of the bolts even came out!! I snapped one, and used the torch on the radiator support body mounts... before sunday, i hope to get the seats out and HOPEFULLY do some sandblasting to the spots where the new metal is gonna go. Thanks for the welcomes!! John |
"1972 C5"
Welcome from socal!
Member
![]() Join Date: Jan 2007
Korey 1955 Bel Air 2 door hardtop 1971 Blazer 4x4 1973 Z-28 Prostreet |
Post Whore
![]() Join Date: Feb 2000
Welcome to the board. I think you are wise to do as much repair work with the K5 on the frame. If you take it off the frame to do repairs you will want to do lots of reenforcing to keep the body positioned correctly. These bodies will sag and get out of shape pretty easy.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
With the aid of the forktruck and a helper, I got the front clip off this morning before work... looks like i'm in for a radiator support as well as inner fenders... bummer... Working on pics..
#13 |
SKINNY TIRES RULE!
Welcome from Seattle. Although what your doing is way, way beyond my skill set, everything I've read on the board says your doing it the right way. Get the body panels replaced while it is on the frame. It is best with the top still in place too. These trucks tend to flex a lot which changes the spacing on the body panels. You may check to see how shot your body mounts are before you align any critical areas.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#14 |
![]() ![]() just a couple of quick ones... |
#15 |
Tot Roddin'
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#16 |
Looks like this one will keep you busy for awhile. Good luck and keep us posted.
#17 |
yeah, she's a mess... I've had her 3 days now...
engine is out, i hope to have the rest of the driveline out tomorrow. ![]() |
#18 |
Designated A-hole!
Welcome to the board from South Mississippi! Make sure to start a project thread on the 67-72 board.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#19 |
Really cool thread.You've got me hooked already. Forklifts, every man should have one...I've been using one for 35 years, amazing what you can do with one.
Good luck, it seems like you have it well under control. Nice to see another one brought back. J Keep the pics. coming, very entertaining
#20 |
![]() Join Date: May 2007
Welcome from sunny New Mexico.
- Jason ![]() ![]() |
#21 |
![]() Join Date: Feb 2004
![]() Man that thing needs alot of work, good luck and I am glad that you are restoring that one and not letting it get parted out and then crushed, You have come to the right place for restoration tips and parts. Good luck and keep those pics coming
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#22 |
