Old 09-20-2007, 07:10 PM   #1
abebummy26
abebummy26's Avatar
Shackles
How much lift can I get out of just shackles? The show truck building guys I know that is how they get most of their lift. But then they also move there spring perches down.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 09-20-2007, 10:00 PM   #2
bigtruck81
Re: Shackles
with just a shackle, you cant gain any lift. you need a shackle flip, which depending on manufacturer you go with, range from 2.5" to 6".
bigtruck81 is offline   Reply With Quote
Old 09-20-2007, 11:26 PM   #3
1969k10stepside
Re: Shackles
The average front shackle wont bring much if any lift,as said above,you need a shackle flip to raise it up--the back end of the truck.
1969k10stepside is offline   Reply With Quote
Old 09-21-2007, 12:53 AM   #4
Southedisto
River life......
Southedisto's Avatar
Re: Shackles
You can gain lift by installing longer front shackles, but your pinion angle is going to suffer badly and you steering is going to be crappy. In the rear, you have to do a shackle flip. If you are going through all that trouble to lift it, I would recommend buying a lift kit.
Southedisto is offline   Reply With Quote
Old 09-22-2007, 01:27 PM   #5
earl87gta
earl87gta's Avatar
Re: Shackles
I think if I remeber right on the shackles are a 1/2 to one so if you go 1in longer it will give you 1/2in but then you have the pinnion angle to worry about. the new big lift kits replace the hole hanger and lower the spring mount I think they do this becuse its easyer to ship a 20 in lift spring would be hard to ship.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-23-2007, 02:59 PM   #6
bigtruck81
Re: Shackles
whose lift kit does this? i've been hanging out at the local 4wd shop alot lately, and have seen ALOT of lift kits. never seen one that did that.
Old 09-24-2007, 10:09 PM   #7
abebummy26
abebummy26's Avatar
Re: Shackles
They Make their own lift kits ie making lower spring hangers
-Lincoln
Old 09-24-2007, 10:22 PM   #8
Prerunner1982
Prerunner1982's Avatar
Re: Shackles
I believe Off Road Design has the shackle flips, you can get them in 2.5-4" lifts.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 09-25-2007, 01:26 AM   #9
earl87gta
earl87gta's Avatar
Re: Shackles
thereare a few companies doing it that way if you look in trunkin mag not 4x4 but any of the show truck mags that have big lifts in them you will see them.
Earl
Old 09-28-2007, 06:23 PM   #10
Prerunner1982
Re: Shackles
The 4x4 mags have it as well...
go to www.Offroaddesign.com
Jon
Oklahoma Roll Call
Old 09-28-2007, 09:20 PM   #11
earl87gta
earl87gta's Avatar
Re: Shackles
here is a pic of an 18 in lift rear kit done that way.
Earl
Old 09-28-2007, 09:21 PM   #12
earl87gta
earl87gta's Avatar
Re: Shackles
Its a shackel flip with long shackle then they lower the front spring mount to ad even more lift.
Earl
