09-21-2007, 03:56 AM | #1 |
Duel Batteries
what do i need to set up duel batteries in my 77 half?
09-21-2007, 06:07 AM | #2 |
Re: Duel Batteries
I'm not trying to be an a**hole, but I'm picturing batteries shooting at each other.
09-21-2007, 06:11 AM | #3 |
>130dB Moderator
Re: Duel Batteries
Spell check will not attack you like a squirrel with rabies... you CAN use it...
Anyway, LMC makes a secondary battery tray for our trucks. I plan to use it in conjunction with the stock battery tray to house twin Kinetik HC1400 power cells.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
09-21-2007, 06:22 AM | #4 |
Re: Duel Batteries
Btw, why dual batteries?
If it's for a sound system, you're going in the wrong direction. Power comes from your alternator. If you add another battery, all that you are doing is adding another power draw. Dual batteries became popular in the late 90's but it was all a scam. If you need more power, go with a dual alternator setup. I know this because I'm an electronics engineer and a former I.A.S.C.A judge. |
09-21-2007, 08:12 AM | #5 |
River life......
Re: Duel Batteries
Dual battery tray, convert to a 140 amp alternator, get a battery isolater and wire it appropriately. Your batteries store the energy for times the energy is needed. I don't fully agree with the "bigger alt is more power", because the battery is what stores the energy for use.
09-21-2007, 11:01 AM | #6 |
www.73-87chevytrucks.com
Re: Duel Batteries
You need this for the dual setup, plus wiring:
http://store.73-87chevytrucks.com/me...ode=73-87UHood
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-21-2007, 02:14 PM | #7 |
THE VILLIAGE IDIOT
Re: Duel Batteries
i used to run dual batterys for my campers,,helps me from haveing a dead batrery when out boondocking....
honestly honey,,i have no idea how that truck got here. |
06-25-2008, 04:16 PM | #8 |
Re: Duel Batteries
Anyone care to post a pic of their dual battery setup? I'd like the second one to be back against the firewall on the passenger side of the engine compartment.
02 Chevy 2500HD D/A EC SB 4x4 MA SCIII trans, EFI Live, 5" exhaust, 5% tint... 83 GMC K30 Crew Cab Short Bed 06 Duramax & ZF6 (to be installed) and more to come... |
06-25-2008, 05:32 PM | #9 |
Re: Duel Batteries
You don´t need dual batteries.. just instal a high output alternator with a bigger capacity battery
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
06-25-2008, 05:47 PM | #10 |
Re: Duel Batteries
I'm pretty sure he asked "how" to set up dual batteries.
Not "should" he set up dual batteries. So maybe instead of assuming y'all know what he's planning on using them for...try asking. |
06-25-2008, 05:49 PM | #11 |
Re: Duel Batteries
Smoke show. Since you mentioned mounting the 2nd battery against the passenger side firewall I can only assume you dont have A/C.. You could always use a battery mount from a CUCV..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
06-25-2008, 06:01 PM | #12 |
>130dB Moderator
Re: Duel Batteries
Dual batteries will really only help with large stereo installs and Diesels.
A HO Alternator is more what someone would need when adding things like electric fans, power interior, winches, extra lights, and high powered stereo equipment. I personally have 3 batteries in my truck, and will be adding a 4th very shortly. I'll have close to 4000CA when it's all done and over 5500 amps on tap for the stereo.
06-25-2008, 06:30 PM | #13 |
Re: Duel Batteries
Winches will drain a battery quick, having a deep cycle battery and a regular battery is better than trying to run a winch off of the same battery you start your truck with and run you other accessories off of. A regular starting battery may not be able to handle being drained and recharged consistantly. Atleast with dual batteries you will always have a back up incase one goes down. If it is wired right a flip of a switch from the cab would change which battery you are running on.
06-26-2008, 01:31 AM | #14 |
I don't think these pills work
Re: Duel Batteries
kinda late but i dont think spell check woulda picked it up because duel is a word. just sayin.
SQUARE84 90 SUBURBAN |
06-26-2008, 01:44 AM | #15 | |
Re: Duel Batteries
C-ya
06-26-2008, 08:14 AM | #16 |
Re: Duel Batteries
06-27-2008, 08:17 PM | #17 |
Manual Transmission Club
Re: Duel Batteries
That would be the challenge not the duel it’s self.
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
06-27-2008, 08:24 PM | #18 |
Fix It Till It's Broke
Re: Duel Batteries
I guess I pictured two batteries with swords fighting to the death
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet |
06-27-2008, 08:31 PM | #19 |
In the Forgotten far North.
Re: Duel Batteries
Dueling Batteries At 20 Paces!! Count Off, Turn And
Z-z-z-z-z-z-zz-z-zzzzzaaaapppppp!!!!!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
06-27-2008, 11:56 PM | #20 |
Re: Duel Batteries
no banjo jokes?
06-28-2008, 08:46 AM | #21 |
Re: Duel Batteries
If a movie was made it would be called " THE CAPACITANCE".
'79' shortbed |
