Restoration Desperation
Brake fluid on floorboard....
I know it ain't good, and it's leaking from the master. I haven't had one off before, do i need a new master, or is there some type of gasket where the master goes thru the firewall? This at least explaines the mysterious missing fluid that had me crawling all under the truck checking fittings and cylinders. Looks like it was running down behind the rubber mat for awhile. It's the standard non-power grakes on my '72.
RD |
its all about the +6 inches
Re: Brake fluid on floorboard....
no gasket, just need a new master cylinder, and you need to pull the carpet/matting, and scrub the hell outts the metal, and the carpetting/matt.
![]() Join Date: Feb 2004
Yup, this is an easy repair, might as well use this time to switch to power brakes.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Power Brakes???? Nonono, that is what thigh muscles are for...............lol
Anyway, thanks for the info, i'll order a new Master. RD |
![]() Join Date: Nov 2006
get the fluid cleaned up or you,ll have no paint left.........
I BELIEVE IN JOHN 3:16 |
Go to advance and get a new master cylender for $20
