Old 09-21-2007, 11:10 AM   #1
GBWatts
GBWatts's Avatar
Horn Issue
I posted this yesterday with no pictures, I now have a few to add. Where the wire is coming out of the inside hub is where the contact post goes, I just put a jumper wire in to see if I could get contact between the cover and the wheel.
I have a 68 Step that I am having problems with the horn contact. I think that I have a bastard steering wheel that uses the round Chevy metal cover with a rubber insulator. The wheel I have is 4 spoke (8, 10, 2 and 4 o'clock). The location of the contact post/plunger does not allow a contact to the cap. Even if it did make contact the contact between the cap and steering column is hindered, I ran a wire between the insulated post and the cap to see if it would work, I literally had to push the cap out of the rubber insulator to make horn contact. I bought a conversion kit and that didn't work. Any ideas?
Attachment 301321
Attachment 301322
Attachment 301323
Attachment 301324
GBWatts
68 C10 Stepside LWB
Howell, MI
GBWatts is offline   Reply With Quote
Old 09-21-2007, 01:39 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Horn Issue
It looks like you have a stock horn button on a aftermarket wheel.
"Assuming" when you touch the wire to ground, the horn honks? What you are missing is the button holder which is a switch to ground the wire when you push on the horn. Here is a later model pic but you get the idea.
sneakysnake is offline   Reply With Quote
