Old 09-21-2007, 11:16 AM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Old Air, Dash or Underdash Mount?
Just wanted to Know which you are Using & Which do u Feel is the Best Way to Go. I did a Search on Old Air & Did'nt really get a Answer from that???
Who would be the Best Board vendor to Purchase a Kit From???
Thanks For Any Help on Subject................
Rick
toomanytoyz is offline   Reply With Quote
Old 09-21-2007, 11:56 AM   #2
BHRS
BHRS's Avatar
Re: Old Air, Dash or Underdash Mount?
From personal experience, go with Vintage Air. I researched restoring the stock AC system and realized it will still be a 35 year old system. I researched aftermarket systems and Vintage Air has a great reputation and reasonable priced. My kit was a little over a grand with free shipping plus TX sales tax. The price was almost equal to rebuilding the stock unit.
I ordered my kit from the Sachse Rod Shop in Sachse TX and they got it in in two day's. I picked it up and spent two weekends installing the kit. It was easy to install...read the directions... I went back last weekend to get it charged and tested-all went well. We put a meat thermometer in the furthest vent and it was reading about 28 degrees on high after running for about 5 minutes. It blows COLD.
My winter project is to pull the seat and carpet to insulate the cab and replace the weatherstripping for a more air tight cab.
Good Luck
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 09-21-2007, 11:59 AM   #3
BHRS
BHRS's Avatar
Almost forgot...it uses the stock controls and vents and no cutting. Big plus is it cleans up the firewall...
Brian
1972 Cheyenne C10
Old 09-21-2007, 12:18 PM   #4
toomanytoyz
Luv the Crewcabs
Thanks for the Info, Got any Pics of the Install??
Thanks, Rick
Old 09-21-2007, 01:05 PM   #5
BHRS
BHRS's Avatar
Not at work, but let me get them to you tonight...
1972 Cheyenne C10
Old 09-21-2007, 02:48 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
There's lots of pictures here. I finished the install months ago, just haven't finished the FAQ thread yet.
http://67-72chevytrucks.com/vboard/s...d.php?t=249479
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-21-2007, 03:37 PM   #7
Zonaman
Zonaman's Avatar
I installed (and favor) an Old Air system. It was the favored system of a local old timer who used to work on these trucks. It's very simialr to the Vintage system. One thing I favored about the Old Air system was the adjustable thermostat on the evaporator. Really helps in high humidity situations. Another thing I like about Old Air is that you can disassemble the in-cab module and replace the fan, evaporator, and heater core, if needed. I'm not sure if the Vintage system allows that or not.
One thing I'll note: These trucks have insulative properties of a sardine can. I'm going through the cab now to add insulation and weather stripping.
To answer your other question you can purchase directly from Old Air
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 09-21-2007, 04:49 PM   #8
BHRS
BHRS's Avatar
On the Vintage system there is a adjustable thermostat under the dash for the A/C. The plenum is sealed and that was a concern I had too about the heater core and any service. I was told that if there is a problem it will have to be sent back to Vintage Air for service.
Prior to installing the heater hoses I flushed the system and used new antifreeze so the core didn't get any junk from the cooling system. I also used compressed air to blow the lines and hoses before hooking up the compressor.
Does the Old Air use the stock A/C controls and vents??? Vintage Air does...
I think either way you will be better off with an aftermarket kit instead of restoring the stock A/C. Just go with something that looks good and doesn't butcher the dash and firewall.
1972 Cheyenne C10
Old 09-21-2007, 06:14 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Not sure you got your original question answered regarding whether to go "in dash" or "underdash" mounting with the a/c system.
I would also like to hear what others say. I would hate to cut into my dash on one of my trucks. On the 69 Chevy, it's already cut up some, so I wouldn't mind a dash system there. I guess it depends on how original you want your truck to stay in case you ever want to go back to the original condition.
Anyway, heres a bump ttt...
68gmsee is offline   Reply With Quote
Old 09-21-2007, 06:52 PM   #10
Zonaman
Zonaman's Avatar
[QUOTE=BHRS;2369242]
QUOTE]
Yeah they do.
By the way I started with a non-AC cab. Just had to cut holes for factory look vents. Came out real nice, uses orginal controls too.
Old 09-21-2007, 07:04 PM   #11
toomanytoyz
Luv the Crewcabs
No Answer Yet................
Thanks for all The Input so Far, This is a Fairly Big Decision to Make so Keep the info Coming....................
Rick
Old 09-21-2007, 07:20 PM   #12
Zonaman
Zonaman's Avatar
Rick
I recommend in dash.
Old 09-21-2007, 07:41 PM   #13
68gmsee
Active Member
68gmsee's Avatar
Hey Zonaman, what's the reason you recommend "in dash?" Is it because of looks?
I kind of feel that under the dash may look too "after markety" (if that's a word). But at least you wont have to cut into the dash.
Some pics of both would be nice...
Old 09-21-2007, 07:51 PM   #14
jamie72
jamie72's Avatar
i`m going with in dash as i have looked at a few of the underdash setups, imo look cheap, and use up alot of space,you also loose leg room for the 3rd person in the middle..
let us know what you go with..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-21-2007, 08:35 PM   #15
jorgensensc
jorgensensc's Avatar
I wanted to use an underdash unit. I know it would look less nice, but It would fit my shop truck look I'm going for. The major problem I have found with teh aftermarket underdash units, both new and vintage, are they stick so far out of you keep the original heater unit. The last one I measured would have hit the front of the seat. Does anyone have a pic of an original aftermarket period correct underdash unit in these trucks??
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-24-2007, 10:17 AM   #16
Zonaman
Zonaman's Avatar
Yup. It because of the looks. Saves a little leg room too. I don't own a digital camera or I'd show you. About the only thing you can see are the vents and the evap/fan unit casing (small) on the firewall under the dash.
Looks kinda like this:
If you dont want to cut the dash they have some under dash vent setups:
Old 09-24-2007, 10:42 AM   #17
67_C-30
I have a radical idea!
67_C-30's Avatar
Is there a system that uses factory AC ball vents. The center vent on the VA system is factory, but the ball vents are not.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-24-2007, 10:48 AM   #18
Zonaman
Zonaman's Avatar
Old Air does.
Old 09-24-2007, 11:51 AM   #19
project1971
project1971's Avatar
well i got an original dealer add on underdash unit for mine. Haven't got it installed yet but it is a one piece with 6 vents in center of dash. has it's own controls for the a/c. The unit came out of a 68 burb.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 09-24-2007, 12:02 PM   #20
67_C-30
67_C-30's Avatar
Old Air does.
Thanks. The factory look on the interior is more important to me than under the hood. I am going to be running a TPI injected L98 engine so I factory look under the hood is a non-issue for me.
My trucks
Old 09-24-2007, 01:19 PM   #21
fastom
That's right, it's Copper!!
fastom's Avatar
This is my setup. I know it's custom but it would work great in any cab with a little work. It's a Vintage Air GenII system.
fastom is offline   Reply With Quote
Old 09-24-2007, 01:28 PM   #22
fastom
fastom's Avatar
One more pic
Old 09-24-2007, 01:51 PM   #23
67ChevyRedneck
VA's kit uses factory balls as well You just have to pay extra for them and I'm cheap.
Their kit is actually "set-up" for them. With the "cheap" balls (again ) the kit comes with a reducer so the heat/air hoses fit.
Jesse James
Project "On a Dime"
Old 09-25-2007, 12:05 AM   #24
jorgensensc
Do you have any pics of it? Maybe a mock up so I can see how far it sticks out?
Shawn
Old 09-25-2007, 09:36 AM   #25
project1971
i can take pics of the unit itself as i am no where near ready to put it in yet. the truck is still completly gutted.
2008 Ford FX2 Screw
