Old 09-21-2007, 07:03 PM   #1
ole school
ole school's Avatar
crew cab build
im wanting to build a 68 crew cab but i dont have a clue on whats needed.from what i see i looks like a surburban rear half but i was wondering about the frame.mine will be a half ton set up.thanks for any help on this
IT'S HARD TO MAKE CHICKEN SALAD WHEN YOUR USING CHICKEN S.........
1968 crew cab build (under construction)
ole school is offline   Reply With Quote
Old 09-21-2007, 09:00 PM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: crew cab build
i would pm rokcrln , he has done this before and could help you . it isnt for the faint of heart........he can get ya started...great guy.....
bad6772 is offline   Reply With Quote
Old 09-21-2007, 10:04 PM   #3
Rokcrln
Rokcrln's Avatar
Re: crew cab build
Thanks for the prop's. I feel the for the best end result is to start with a full burb. You will need a truck cab for the rear section and parts of the doors and floor. You will need to add some to the frame depending on what wheel base you are looking for and oh yah alot of extra time (100+ hours for starters if you work fast) money and parts.
My personal thoughts are unless you just have to have one, have the skill to do it and the time to do it from start to finish I would not start. I have heard from alot of guys that have started the job only to give up after a burb and truck is all cut apart. Here is a build thread of one that I worked one for a customer that might give you some more info.
http://67-72chevytrucks.com/vboard/s...d.php?t=188993
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
