10-01-2002, 01:29 PM | #1 |
Reversed Q-jet carb.........
I am running the orriginal Q-jet carb on a mostly stock 350. For better off road performance, steep hills and angles, I have heard that you can mount the carb backward useing a van accelerator cable.
Can anyone tell me more about this? What year van cable? How well does it work? What all do I need to get?
I need all the help I can get. |
10-01-2002, 01:47 PM | #2 |
Aren't the holes in the manifold different sizes for the primaries and secondaries with a Quadrajunk?
Eric 1969 K20, 465/205 package |
10-01-2002, 03:04 PM | #3 |
Ive never heard of mounting the King of off-road carbs, the Q-jet, backwards.
The more I learn about women, the more I love my truck. |
10-01-2002, 05:33 PM | #4 |
yup. thats the king !
10-03-2002, 02:55 AM | #5 |
i cant see the secondaries being able to open very far when carb is mounted backwards,,, as far as i have seen and heard, the colorado offroaderws dont do this, who made mention of this to you ?
interesting,.. |
10-03-2002, 07:24 AM | #6 |
Some of the Ford and Dodge guys do mount Q-Jets backward. I am pretty sure they do it to get a slight advantage when climbing very steep hills. This would be since the bowl would then be on the low side, so gas would not spill out the vents. This would be where Q-jets are being adapted to a square bore manifold, so it doesn't really matter which way you mount it, aside from getting a throttle cable hooked up. I think the same benefit can be achieved by extending the bowl vents with a piece of hose, and running the carb the way god intended it.
Tim |
10-03-2002, 04:05 PM | #7 | |
10-03-2002, 05:51 PM | #8 |
correct me if I'm wrong but turning a q-jet around backwards??
It has been awhile but how in the $%^& does that work? Is this really a joke post? |
10-04-2002, 07:48 AM | #9 | |
Tim |
10-04-2002, 01:30 PM | #10 |
I think the carb would react in a similar manor to climbing a steep hill as it would to rapid acceleration.
10-18-2002, 10:02 PM | #11 | |
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
10-18-2002, 11:42 PM | #12 |
You could take a quad to holley adapter, then also add a holley to quad adapter but turn it around. Should fit just fine I believe.
10-18-2002, 11:44 PM | #13 |
2 of these should do the trick;
10-29-2002, 02:32 AM | #14 |
Here is a thread that has some pics and other information about how it works.
http://www.pirate4x4.com/forum/showt...threadid=90948
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
