Old 09-22-2007, 03:15 PM   #1
energiesource
Taking the bed apart?
So I have limited space, and manpower, so i cant really just undo the bed to frame mounts and lift it off, is there anyway i can take it apart panel by panel? and i cant get the huge phillips screws out at the front of the bed, any help with that?
energiesource is offline   Reply With Quote
Old 09-22-2007, 03:17 PM   #2
1969k10stepside
Re: Taking the bed apart?
Unbolt the bed from the frame and move it back so you can have access to the front bolts.For the phillips screws,my cordless drill got them out.You will need to get the spotwelds off at the tailgate end that hold the floor to the sides but other then that it's just removing bolts.I've found with a impact just tighten them till they break as it's a PITA to unbolt them.
1969k10stepside is offline   Reply With Quote
Old 09-22-2007, 05:04 PM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
i heated the phillips screws to red hot with my torch & while they where still hot they just threaded out easily... 1969k10stepside is right, just break off the side bolts or cut them off.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 09-22-2007, 05:52 PM   #4
RedZ71
Junior Member
RedZ71's Avatar
1/4" thick cut off wheel.... i just ground one down until the phillips head fell off.
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
