Old 10-01-2002, 02:31 PM   #1
COBALT
COBALT's Avatar
Front-end goes back together this weekend!!!
I'm really excited. After 3 weekends of work I'm finally going to be able to put the font-end back together.
Everything got cleaned and painted. EVERYTHING. All the new parts from Early Classic got cleaned, masked, and given 2 coats of Rust-o-leum Gloss Black. The upper and lower control arms I wire brushed for about a million years until I had rust-free metal, and those got 2 coats of the same paint (I had to buy a can that I could brush on because of those wierd spot-welded towers where the bumpers go on the lowers. What the hell are those things??? Had to get paint inside them... :P).
The coil springs I debated about what to do with. I finally decided to wire brush them too even though it was going to be a major pain, but I figured out a trick! To do the wire brushing I had a 3/8" drive power drill, and 4 different wheels. I used the cup to brush the entire outside of the coil to get it clean. Then I used a 12" extension, and placed the cup inside the coil, and attached the extension from the outside. Then I simply turned the drill in a big circle from the outside while I wirebrushed the inside of the coil. I finished it up with the regular wheel to get in between the coils, and they looked brand new!
I used Silver Metalic Rust-o-leum on the coils after they were cleaned and dried. They look outstanding.
Finally, I didn't want to disconnect my brakes so I cleaned the big yoke-thing the upper control arms, the coils, and the brake lines attach to while it was still on the truck. Scrubbed it down with a couple of wire brushes and the wire wheels. Cleaned the spindles the same way. I have each of the complete drum assemblies + spindles each sitting on a piece of douglas fir I split probably 5 years ago so they're out of the way.
I'm getting a digital camera soon, and I'll snap some shots before I start assembly on Friday evening. I'm going to have a picture perfect front-end on a rusty body, falling apart bed truck, but oh well. One section at a time.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-01-2002, 04:17 PM   #2
Spoof
Spoof's Avatar
Your just ahead of me Cobalt. I'm just fixin' to paint all my tie rods, idler, pitman and control arms and spindles. The frame is ground down and ready to go, just a final clean with laquer thinner and the painting begins. It will give me a feeling of progress that will hopefully last me through a broke winter.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
