Old 09-22-2007, 05:48 PM   #1
wedgemon
wedgemon's Avatar
Cool My first clue was . . .
My first clue was the ride in the yet unregistered 73 Blazer. Just replaced the master cylinder and took it for a test ride. It seemed to be crabbing down the street some. I figured I gotta check tire pressure. So, the test drive tells me I need to add some ATF because she's slipping bad - slammed into 1st at two different stops. I get it home top off the ATF and decide to take her to the corner gas station for a little go juice. While I'm fueling, I look at the stretched taut Ebrake cable. I thought, "That doesn't look right.."
And I attrbute it to the 4 inch lift the P/O put on her. Then I look at the axle plate, u-bolts and spring pack and noticed the centering pin about 3 inches aft of the rear of the plate.
No more thinking, That REALLY Ain't Right!!
I guess the 2 years since she's been driven much at all, and the tranny slamming, she managed to walk the axle. The other side looks OK.
Looks like I've got a Sunday project...
- Dave
I'll post pics later...
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 09-22-2007, 08:13 PM   #2
wedgemon
wedgemon's Avatar
Re: My first clue was . . .
Here's the pics...
First the Passenger side , showing the wheel & axle, relatively, centered in the well. And the EBrake cable flexed....
And now the drivers side... Note the taut cable and gaps forward & aft of the wheel...
Thing really drive funny like that! Any advice or cautions???
Thanks,
- Dave
Founding Member:
Old 09-22-2007, 08:14 PM   #3
wedgemon
wedgemon's Avatar
Added pics abive, I think??
Founding Member:
Old 09-22-2007, 09:36 PM   #4
tvblazer78
Low & Fast!
tvblazer78's Avatar
Well, you may have to run out the bolts for both sides on your u-bolts. this will let is slide back into the place better. This is best if you use jack stands on the frame and a floor jack under the axle so you can get it lined up better.
Good luck,
Tran
tvblazer78 is offline   Reply With Quote
Old 09-23-2007, 01:56 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
My thoughts are someone didn't put a long enough center pin in that spring. It should be almost impossible to have that axle walk if it's pinned properly
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-23-2007, 02:09 AM   #6
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 09-23-2007, 12:17 PM   #7
wedgemon
wedgemon's Avatar
I've never done an axel. Is the spring pack drilled thru all the leafs?? Should I look into a new pin??
- Dave
Founding Member:
Old 09-23-2007, 04:49 PM   #8
tvblazer78
Low & Fast!
tvblazer78's Avatar
Yes, it is thru all of them. If it looks like it's rounded or short, then you my need a new one.
- Dave
Old 09-24-2007, 12:05 PM   #9
wedgemon
wedgemon's Avatar
Found a pin from the scrapped 79 K20 that worked. Torquing it was fun! My shoulders are killing me! She tracks true now though.
Thanks for all the help!! This site really is the best.
- Dave
Founding Member:
Old 09-24-2007, 05:51 PM   #10
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sweet!!
Old 09-24-2007, 10:52 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Cool! Glad we could help....
Articles-
"Refining Sierra"
