09-23-2007, 08:57 AM | #1 |
Junk/Daily Driver Club
Radiator repair
I have a small hole in an almost new radiator, close to the top of the tank. What is the best solder,flux and heat source for this repair?
Thanks, Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! |
09-23-2007, 09:32 AM | #2 |
Active Member
Re: Radiator repair
Unless you're an expert at soldering with high heat I would just take it to a radiator shop. Not that expensive to just solder a hole. They did mine for less than $30 a few years ago and they went ahead and vatted it.
Never tried the solder but I've tried several methods in the past and none seem to be a good permanent fix. I tried an epoxy once. The epoxy held up well for about 6 months but I had to crush the tube. All in all, it was more work to save a few bucks than to have a pro do it. Just my .02 |
09-23-2007, 09:49 AM | #3 |
Re: Radiator repair
a rad shop is your best bet but if you can see it, JB weld will fix it and never come back out...what ever you do do dont use stop leak or anything to that nature
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB, "some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno |
09-23-2007, 12:04 PM | #4 |
Re: Radiator repair
if the tank is leaking and not the tube and the tank is brass i'd just use lead/tin solder and flux cleaniing it real good the tank must be emptyedand gently use a proprane torch apply the solder
09-23-2007, 01:54 PM | #5 |
Re: Radiator repair
What we do is we use JB weld... It works (circle track) and hasnt given us any trouble.. I also use it on the radiators for motocross. Good luck!
09-23-2007, 02:06 PM | #6 |
Re: Radiator repair
this is a temporary fix but i know a guy who had a farm truck with a hole in the radiator and he used half a can pf copenhagen and it stoped the leak for a week or so
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block |
09-23-2007, 02:08 PM | #7 |
Re: Radiator repair
i was surprised it worked but it did
he also did it to an old grain truck that was on their auction and it lasted almost a month
09-23-2007, 02:24 PM | #8 |
Re: Radiator repair
30 buck to fix a .50 problem. i had one get banged up pretty bad , pretty good size hole in it. i took it out soldered her up and still driven it today a few years later. solder that bad boy!
09-23-2007, 02:34 PM | #9 |
Re: Radiator repair
I use silver solder on copper piping, so I think it would work fine on a rad tank. It will definatly hold the pressure.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-23-2007, 05:02 PM | #10 |
Re: Radiator repair
Attempting to solder a seam can be frustrating as the area where the old and new solder meet always seemed to leak for me sooner or later. A pin hole is much easier to solder. Make sure the area is CLEAN down to bare shiny metal and flux it well than use a little heat from a propane torch to warm the area just enough to get the lead/tin solder to flow and fill the hole.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
09-23-2007, 09:47 PM | #11 |
Re: Radiator repair
Thanks for all the information, I think I`ll try soldering it one of these weekends. I gess i`ll try using 50/50 solder, that dosen`t need a lot of heat to flow.
Thanks, Willis
