Old 09-23-2007, 11:02 AM   #1
Rust Buster
Rust Buster's Avatar
Bending ceramic coated headers?
My new Thorley headers are will not fit right because they hit the ORD heavy duty front shackles I bought. I figure if I can bend them a little then I will be alright. It's either that or cutting off one of the three bolt holes in the collector flange.
Does anyone know if I can heat up and bend ceramic coated headers without doing major damage?
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 09-23-2007, 04:31 PM   #2
fastom
That's right, it's Copper!!
fastom's Avatar
Re: Bending ceramic coated headers?
Kiss the coating GOODBUY if you do that.
fastom is offline   Reply With Quote
Old 09-23-2007, 04:36 PM   #3
70GMCer
70GMCer's Avatar
That coating is pretty tough. I have Hedmens and had to bend in a couple of places to fit. I even had to use a vise on a couple tubes without any damage. Keep in mind that mine were Jet Hot coated......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-24-2007, 11:18 AM   #4
diggertodd
diggertodd
diggertodd's Avatar
Try bending your ceramic garden gnome and see what happens , might get away with a "tweak", but I'll guarantee you that you will have separated the coating from the metal - and rust will be next.
diggertodd is offline   Reply With Quote
Old 09-24-2007, 02:42 PM   #5
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Bending coated headers is a BAD idea. You might as well scratch them with a file and put them is a salt brine for a while. You will cause tiny cracks in the finish, this will lead to seperation and will attract moisture which will cause rust, and those tiny cracks will lead to flaking / chipping finish.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
