Old 09-23-2007, 12:51 PM   #1
tx71smallblock
tx71smallblock's Avatar
oil leak
i have an oil leak on my 350, it seems to be coming from between the head and the block but i didnt know oil went through the block like that. it takes it awile to show up after you start it. i have already ruled out the valve cover and the oil pressure line behind the intake. WHAT IS IT!!??? Please help.
p.s. i have already tightend the head
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 09-23-2007, 01:31 PM   #2
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: oil leak
It might be coming from the back of the intake manifold and running down the backside of the head. Either one of 2 places I can think of... the corner of the manifold itself or one of the back bolts which tend to leak also.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 09-23-2007, 02:59 PM   #3
bryanw1968
bryanw1968's Avatar
Re: oil leak
What he said.
bryanw1968 is offline   Reply With Quote
Old 09-26-2007, 09:53 PM   #4
tx71smallblock
Re: oil leak
so there is no way for it to be leaking from the head, cause i have already retighted the bolts.
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 09-27-2007, 06:40 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
Re: oil leak
Not necessarily so, you might have over tightened them on accident.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-27-2007, 08:28 AM   #6
trjohnso
Guest
Posts: n/a
Re: oil leak
You can get a dye to put in the oil to pinpoint exactly where the oil in coming from. You might have to rent a ultraviolet light with enough intensity to see the dye.
Old 09-27-2007, 08:36 AM   #7
Bucky71
Re: oil leak
It looks like the oil is coming from further up. Intake manifold?
Bucky71 is offline   Reply With Quote
Old 09-27-2007, 09:19 AM   #8
cdowns
cdowns's Avatar
Re: oil leak
theres an allen head plug partially under the head near where the oilpressure sending line attaches that may have loosened up its doubtfull but still a possibility and would require removing head to check// id go with the intake theory myself
Old 09-27-2007, 08:56 PM   #9
tx71smallblock
Re: oil leak
how much pressure is too much on the head bolts, like in ft.lbs?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
