Official Site Guitar Shredder
A arm shaft/bushings install?
i got everything to get my front suspesion. completely rebuilt. upper /lower ball joints> upper/lower shafts/bushings......my question is what is the correct way to install the upper lower shafts,? when i put the shafts in how do i got about centering everything up? any help would be great thank you tony
Re: A arm shaft/bushings install?
Is this just a dumb question? or know body knows?
I can't answer about the 'correct' way to install the bushings on the shafts since I have no formal GM training.
I can say I install them trying to keep everything as centered as possible & have never had a problem (I've put together front ends on @ least a dozen 64~87 trucks). Anything more specific you need to know?
thanks scotti all i needed
Active Member
![]() Join Date: Oct 2006
I did mine as best as I could and then took it down to the alignment shop and let them do the rest.
