Old 10-01-2002, 05:23 PM   #1
1967LWBstepside
'Heavy Metal' Redefined.
1967LWBstepside's Avatar
Anybody powder coated valve covers?
I have an aluminum marine valve cover that I want to put on my 250. It needs cleaning and has been painted black already. If I powder coat it chevy orange or something other than black, will the engine heat burn the powder coating so that it looks dirty or burnt?
If powder coating is best, where can I get it done? I haven't found any local shops that do it and was wondering if I could mail it somewhere to get coated?
Thanks in advance for the advice.
Mike
1967 C10 LWB stepside, 250 engine, GM HEI, aftermarket A/C., Clifford Performance intake, Stovebolt split headers, Carter AFB 500, X-pipe & Dynomax Super Turbos, 1 piece custom driveshaft, cyprus bed wood & stainless bed strips.
Starkville, Mississippi | My Truck Page
1967LWBstepside is offline   Reply With Quote
Old 10-01-2002, 05:54 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
The heat should not bother the powder coating. It would have to get up over 400 degrees to bother it. I could put you in touch with my shop. They have stuff shipped to them from all over the country. They do a lot of automotive pieces to. Let me know if you are interested and I will get you the information.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-01-2002, 06:44 PM   #3
Stepside
Gasser
Yes, valve covers are a favorite to powder coat. I use the Eastwood kit. Works great. You can even do a gloss clear on the aluminum.
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Old 10-01-2002, 07:34 PM   #4
minibike
minibike's Avatar
If you do it yourself, be sure and bake the aluminum for a while to let the oils and stuff come out of the pores prior to powdercoating. If you don't, you will end up with fish eyes and blisters. I blast clean, bake, then sweep blast it again, then coat. For steel, this is not necessary.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 10-01-2002, 08:17 PM   #5
superchevy
Got big-block?
superchevy's Avatar
I have had probs with powdercoated aluminum intakes "yellowing" slightly at the exhaust crossover passages.
Never had any probs with p-coated valvecovers though.
Be sure to "cook" the impurities out like minibike suggested.
Here's a pic of some cool Cal Customs I had powdercoated.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 10-01-2002, 09:24 PM   #6
JD72
WTF
Mike you will not have a problem with it, we are gonna try a plastic ford tommorrow I can get you a one day turn around time if you need. Just pm me or e-mail.
Jay
Some people are wise, some people are otherwise.
72 cheyenne primer factory air lowered rallyes with flat caps flowmasters 12 bolt 3.73 350/350 combo needs rockers . Cowl hood installed.
81 Malibu wagon lowered with 17's bright ass yellow and v-6.
71 225 Electra all original 455/4
81 z28
JD72 is offline   Reply With Quote
