09-24-2007, 06:55 PM | #1 |
Choke cable kit
Just bought one for the Jimmy. It's one of those universal heavy duty one's for trucks that you find in the "HELP" section of the auto store. I have no place to really to mount the two little cable brackets that the kit came with without removing the return spring bracket, which is about the only other mounting hole.I dont have any pics, but I am mounting it to a Rochester 2GV. (Converting to manual choke.) I reamed out the choke cam hole of a holley reman and used it instead of the original one because of a breather clearance problem. I tried zip tying the choke cable housing in a few places, but it didn't work too well. Anyone got any advice? Are they just temperamental? Does the cable sleave need grease?
Thanks. SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD Last edited by SLIMJIM; 09-24-2007 at 08:05 PM. |
09-24-2007, 10:03 PM | #2 |
blood type; Retumbo
Re: Choke cable kit
those cheap cables are JUNK!!!!!
find the most expensive and largest diameter one you can get. I fought this on a customer's 67 mustang. I went through 3 of them before the boss got me a good one. I'll have to ask him where he got it. |
09-25-2007, 01:59 AM | #3 |
Re: Choke cable kit
Junk X 2.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
09-25-2007, 07:02 PM | #4 |
Re: Choke cable kit
Thanks for the replys. If your boss tells you where to find one, gimme a holler.
SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD |
09-25-2007, 08:28 PM | #5 |
huh?
Re: Choke cable kit
Definitely keep us updated. I put one of those universal choke cables on my truck, and cut it to fit. It works ok, but just feels cheap. I'd rather have a nice thick one-piece inner cable that's rather rigid (rather than the cheap braided one), that way I know for sure the choke is fully open.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
09-25-2007, 08:33 PM | #6 |
Re: Choke cable kit
I found this link. The same kit I bought. He says it works when you trim the cable length properly, but doesnt mention specifics.
http://thunkgeek.com/?p=14 SLIMJIM
09-25-2007, 11:11 PM | #7 |
Texas Big Wig
Re: Choke cable kit
I use a fuel kill cable for a John Deer tractor
they have a really good cable & the casing has a Teflon coating on the inside, so they never rust Just go down to your local JD house & ask them for the universal kill cable It has a red knob with a crossed out fuel pump symbol on it, I take a scotchbrite pad or similar and buff it off If you want I can get pics for you soon |
09-26-2007, 06:26 AM | #8 |
Re: Choke cable kit
LMC lists a '67/'68 Choke Cable: p/n 30-2642. Knob is p/n 30-2640. I know LMC is mostly cheap Chinese junk now, but it will probably fit better than the other Chinese junk from the "Help" rack.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-26-2007 at 06:31 AM. |
09-26-2007, 07:12 PM | #9 |
Re: Choke cable kit
Spraybomb,
Pics and a description of how you mounted it would be great. I will check into that cable. 68OS, I will see if they have a pic of it on their site. Thanks. SLIMJIM
09-26-2007, 09:10 PM | #10 |
Texas Big Wig
Re: Choke cable kit
I'll try to get you some pics soon
I mounted it in a hole somebody had drilled it the dash, but on my dads truck we plan to find a way to use the stock knob & location |
09-27-2007, 07:47 AM | #11 | |
Re: Choke cable kit
Slimjim: Try using powdered graphite to lube the cable shaft. Just like a speedo cable.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-27-2007 at 07:50 AM. |
09-27-2007, 07:00 PM | #12 |
Re: Choke cable kit
Just found this on the net....but it's in the UK....
http://www.nfauto.co.uk/choke_cable.htm And I think they had them made...... Spray bomb, If you could, get me a part number on that kill cable. I am going to try and go to the local dealer and get one.Thanks. 68OS, I found some cable grease and will try that. It might just seep through the cable housing though. I actually asked for the graphite stuff and they were out. Thanks. SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD Last edited by SLIMJIM; 09-27-2007 at 07:04 PM. |
09-28-2007, 06:11 AM | #13 |
Re: Choke cable kit
I backdated my '71 Jimmy -- around 1999 when I put in a new crate motor -- with a Chevy choke cable out of a junkyard, I think. I used the method I mentioned above to mount the choke cable knob under the wiper switch. Originally the truck had a Quadrajet with the bimetal strip auto-choke. After the PO's motor lunched -- I put a Carter 9605 AFB on the new engine. Since I live in an area [mountains/ desert, etc.] where I might encounter a wide range of ambient temperatures and/or atmospheric pressure changes, I prefer the manual choke.
