Old 09-24-2007, 07:34 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
stock VS tubular control arms question
Just wondering how much lower I would be if i went with tubular control arms and no cup as opposed to a cut down cup and a stock control arm? just wondering if anyone has any experience in this issue?
Jason
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 09-24-2007, 08:01 PM   #2
red02chevy
Re: stock VS tubular control arms question
what year truck?
red02chevy is offline   Reply With Quote
Old 09-24-2007, 10:22 PM   #3
pissonNOS
senior member
pissonNOS's Avatar
ya sorry bout that guess it would help its on my 69 GMC the one in my avatar
69 GMC bagged
Old 09-24-2007, 11:55 PM   #4
red02chevy
When I did the swap on my 86, it got me down about 1 inch lower. I was running 1 1/4 cups. I think I have some pictures:
Old 09-25-2007, 12:10 AM   #5
pissonNOS
senior member
pissonNOS's Avatar
any problems with rubbing with 1 1/4" cups?
69 GMC bagged
Old 09-25-2007, 12:28 AM   #6
red02chevy
I heated the control arm where the bag was rubbing and beat it out so i had plenty room. Other then that no.
Old 10-15-2007, 09:50 AM   #7
hotrodhomi
hotrodhomi's Avatar
would a larger cup require less beating? Where does the bag rub?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 10-16-2007, 03:23 AM   #8
Cannon007
whats the weight of those compared to stock? it remove much weight?
Cannon007 is offline   Reply With Quote
Old 10-16-2007, 03:55 AM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Taller cup=fewer clearance issues, but less drop. You will need to dent the area around the spring pocket, mostly on the shock side. '73-up arms have a shallower pocket that requires less clearancing and allows a shorter cup.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-17-2007, 11:16 AM   #10
hotrodhomi
hotrodhomi's Avatar
If you change the lower arms to the "73 + style do you need to change the uppers as well?
'66 impala ht
Old 10-17-2007, 11:18 AM   #11
hotrodhomi
hotrodhomi's Avatar
Are the arms the same for 3/4 ton trucks? 4x4?
'66 impala ht
Old 10-17-2007, 12:05 PM   #12
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
I have some tube lowers for $150 you just need to make your own crosshafts and get bushings. Used them on the new arms we built. PM ME
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 10-17-2007, 01:44 PM   #13
hotrodhomi
hotrodhomi's Avatar
PM sent
'66 impala ht
Old 10-19-2007, 12:56 PM   #14
hotrodhomi
hotrodhomi's Avatar
Are the arms the same for 3/4 ton trucks? 4x4? TTT, for unanswered questions.
'66 impala ht
Old 10-19-2007, 02:59 PM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Not necessarily. Might as well do them both IMO. 3/4 ton are the same as the early arms. You want late 1/2 ton arms.
-Chris
