Running Poorly
I finally got tired of my 305 running on 5 or 6 cylinders so i got new plugs and wires for it. Now it pops and backfires and misses and lurches and chokes. It does alright in Low gear but its the worst when im in first gear until i give it some gas. then when i shift to second it chokes then takes of and accelerates fine until i get to third gear and it starts to diesel. it backfires and misses while im maintaining speed on a flat road but it idles fine. So whats wrong
Its no disgrace being poor. Its just inconvenient. |
Re: Running Poorly
Kinda sounds like you swapped a couple of wires to me. As in put them in the wrong place. Check numbers 5 and 7 those are an easy mistake.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
Re: Running Poorly
All of the wires are connected to the correct plug and terminal on the distributor
Re: Running Poorly
come on, i know theres gotta be some expert that can help me out here
Right on the line, baby!
Re: Running Poorly
I'm no expert, by any means. But have you considered the accelerator pump? How about the fuel filter? A little more information about the condition of the rest of the engine would help.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
BAD BOW-Silverado XST
Re: Running Poorly
Check the timing, cap, bad wires, spark arching and advance.
#7 | |
Re: Running Poorly
And i asked a guy where i work about this and hes says it wouldnt be the timing, it might be the valves. And he told me to stick a vacuum gauge on it and it should read 14lbs at idle
Its no disgrace being poor. Its just inconvenient. Last edited by 1984Silverado4x4; 09-25-2007 at 09:55 PM. |
Re: Running Poorly
sorry i dont know what those are or how to check them
Its no disgrace being poor. Its just inconvenient. Last edited by 1984Silverado4x4; 09-25-2007 at 09:56 PM. |
Dark Heart Motorsports
Re: Running Poorly
might wanna check the distributor bro...its a common problem, a few degrees off can make that difference....loosen it up at the bolt a smidge to where you can free hand turn it..
from there turn it till it idles smoothly, then have someone turn off the truck ignition, and tighten the bolt down exactly on the perfect spot. if that doesnt work, then unfortunately there are wires swapped or rubbing
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
#10 | |
Re: Running Poorly
played with the distributor and it runs good at idle. the wires are all in there correct spots and there not rubbing
Re: Running Poorly
funny, i got the same problem on my 350. idles fine then once you shift into drive it stalls and sputters. i just got the thing and haven't done anything to it yet. don't know when the last time the oil was changed or the tranny was flushed. first place i'm going is to change that oil. that sludge will do that to it once you put the motor under a load. then it's to the ignition.
It's peanut butter jelly time.'74 GMC 3/4 TON 2WD LB |
Re: Running Poorly
Sounds like a bad or stuck intake valve. If a lifter mushrooms at the bottom too much it can get stuck in its cylinder and hold the valve open and pop through the carb. Same pop if the valve goes bad.
#13 |
Re: Running Poorly
Sounds like i got some work to do to it then. better get my other truck running i guess.
#14 | |
glamoros piece o' lowlife
Re: Running Poorly
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
#15 |
Re: Running Poorly
well it wont even idle now. it just backfires and dies. I think when i get my other truck back from the shop ill just rebuild this ones engine.
I was told that by the guy i work for it should be 14 something and i was sure he said pounds but maybe he did say Hg.
Its no disgrace being poor. Its just inconvenient. Last edited by 1984Silverado4x4; 09-27-2007 at 07:18 PM. |
#16 |
Wishin' I had more money!
Re: Running Poorly
This really sounds ignition related.
Try unplugging the vac. advance on the distributor and plugging the carb (so no vac. leak) and run it then. Also sounds like it could be a bad pickup coil in the dizzy... |
#17 |
Stepside Fanatic!
Re: Running Poorly
Yeah, jeeze, don't go rebuilding it because of this problem! If all else fails you can actually (shudder at the thought!) take it to a mechanic, right? Anyhow, you might want to check your vacuum lines, a vacuum leak can make it run funky and pop and sputter. I prefer to use WD 40 instead of carb cleaner (MUCH less chance of an engine fire that way) and spray around your vacuum lines while it's running. If it smooths out when you spray it, then there's a vacuum leak. Replace the hose for a buck or two and you're good to go!
#18 |
Parts and more parts
Re: Running Poorly
Troubleshoot first, THEN rebuild if all else fails. It will make you mad to rebuild and find out later that there was a simple answer to the problem. The coughing and sputtering problem--Did it start AFTER your change out of the plug wires and ignition parts? If so, then go back to what you know has changed. The coil could be not grounding properly, the plug wire might not be right, even if you checked them--have someone back you up on that--it is easy to get skunked by something that you have been looking at to long.
The ignition module (inside the distributor) is another source of pain in these trucks. Get a new one--it is cheaper than a rebuild and if it is not the proble you are still better off. Be sure to use "Dielectric grease" when you put the module i n, so that it does not go to ground. If you have already changed out the module---did you use the grease---if not put some in> That intake vacuum reading is in inches not pounds and 12" to 14" is a normal expected reading, look at this. Do a compression check on the engine and see if the valves are bad or not. The carbs are prone to having accelerator pump problems --rough acceleration issues and also wear problems inside the body that cause poor transition from the primaries to the secondaries (rough/harsh cutting out when you accelerate hard). Do you know if the truck has experienced a failure of the timing chain in the recent past? GM has a problem in this area and if it fails there are things that will happen due to that. Bent valve pushrods or bent valves is common and if so they may need to be repaired through head work. This will give a poor performance issue and rough engine operation |
#19 |
Re: Running Poorly
All else has failed it ran for about 2 seconds today then coughed and died and never started again so i didnt get to work today. It needs a rebuild anyway and i was planning on doing it some time during my ownership.
#20 |
Re: Running Poorly
[QUOTE=1975stepside;2378202]Yeah, jeeze, don't go rebuilding it because of this problem! If all else fails you can actually (shudder at the thought!) take it to a mechanic, right? QUOTE]
I cant afford to take it to a mechanic. If they fix this something else will break. Besides i like the look of a clean painted engine with shiny chrome.
#21 |
Re: Running Poorly
I find it best to stop at a point and start over . How was it running before you changed the plugs and wires ? If it was good and you were just doing a tuneup , something didnt get put back correctly or they sold you the wrong plugs . What plugs did you install and at what gap . It sounds like the plug wires are off one terminal and the timing is way retarded . If a previous owner pulled the distributor and didnt get it back in correctly , they may have jumped the wires around the cap to compensate . Did you make sure where the number one wire was connected on the cap before removal ? Main thing is how did it run before ? Frank
Born and proudly residing in a Red State ! |
#22 |
pkbinplano
Re: Running Poorly
almost sounds like a cracked cap
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat |
#23 | |
Re: Running Poorly
| Bookmarks |
