Old 09-24-2007, 11:12 PM   #1
chevymotocross
chevymotocross's Avatar
Just installed a new tank and pump.... now not working!
I really want to cry. For those of you who have replaced a fuel tank on a 73-87, you know how difficult it is. I got a new tank, and carter pump and strainer for my 87. It took me litterally 4 hours to line everything up and I finally got it. I put a little bit of fuel in, to make sure she would start and run on that tank. She fired up and ran for about 30 seconds. I turned it off, and drove to the gas station on my other fuel tank. I put $10 of fuel in, select the switch over to that tank. My gauge goes way past full and it won't start or run on that tank I think I would like to scream.
chevymotocross is offline   Reply With Quote
Old 09-25-2007, 11:31 AM   #2
chevymotocross
Re: Just installed a new tank and pump.... now not working!
And just to add, this must obviously be a grounding issue. For the guage to jump wayyyyy past the full mark on $10 worth of fuel, and for no fuel to be pumping, it's shorting somewhere. On my 87, it consisted of 3 fuel hoses (which I re-installed correctly), an actual wire that had a 2-prong connector at the end, I'm guessing that is for the sending unit and pump, a very thin, which appeared to be a ground wire, and then at the filler neck, a grounding strap wire. That very thin "ground wire", I had to cut in order to drop the old tank, there was no room to see where it actually connected. On installation, I twisted the wire together and added a crimp. Just because I cut it, does not mean it can't work, it's intertwined, it has to make contact! I will take a look again this weekend but if it's nothing to do with the wiring outside the tank, maybe the new pump is just faulty. I saved the working old one just in case.
Old 09-26-2007, 12:36 AM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The one you pulled out worked?
Can you even tell if the motor is priming or is it doing nothing at all?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-26-2007, 11:03 AM   #4
chevymotocross
The one I pulled worked, the only reason I replaced the pump/strainer was because the job is tough enough replacing a tank, so I figured while I'm there why not throw in a $40 pump. It must not be priming at all, because as soon as I would switch to the auxillary tank, the truck would fire right up. Here is the wierd part, yesterday I go to show a buddy what is wrong, and the pump operates and has an accurate gauge. I was able to drive around all day yesterday on the new pump. I will see what happens today. I still don't trust it though. For it to not work for an entire day, after I installed it, still does not sit well with me.
Old 09-27-2007, 11:05 AM   #5
Captkaos
Captkaos's Avatar
That is weird. BTW, the ground goes from the tank to the frame.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 09-27-2007, 10:21 PM   #6
chevymotocross
I am dropping the tank. It lasted a couple days but today I went over a speed bump and it happened. I think the crimp I used is not working properly.
Old 09-27-2007, 10:37 PM   #7
1975stepside
Stepside Fanatic!
I work in an Auto Electric place. One of our techs says he'd only have HALF the business if it wasn't for bad butt-connector connections. He ALWAYS solders and shrink wraps connections, and it prevents us getting comebacks.
1975stepside is offline   Reply With Quote
Old 09-28-2007, 10:17 AM   #8
rfmaster
rfmaster's Avatar
The problem is not with a butt connector. The problem is that just about every single common crimper on store shelf (you know 19.95) will not form a proper crimp. Professional grade crimping tool costs hundreds of dollars - usually available only from electrical connector manufactures -AMP, PANDUIT, and others. In addition, commonly available butt connectors are incorrectly designed - hint Chinese made garbage. Most of the 'butt' connectors are really Siamese junctions which require the two wires to overlap each other before being crimp. So, what you have is a perfect storm - bad tool and incorrectly used connector.
I agree that forming a proper solder, heat shrink it and wrap-it - it is still better than nothing.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
