Old 05-01-2002, 03:45 PM   #1
neonlarry
neonlarry's Avatar
Question Valve cover gaskets
I am going to be replacing the valve covers on my truck and I was wondering what would be the best valve cover gaskets to use. Do you need to buy the ones that cost $35-50? I was thinking about using the Mr Gasket Ultra Seal ones, are those any good? I am going to be using cast aluminum valve covers with studs instead of bolts.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-01-2002, 04:12 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I use Fell-Pro, almost exclusivly. No problems as of yet.
The rubber ones are ok, but I saw no reason when used them to buy them again.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 05-01-2002, 05:05 PM   #3
busterwivell
Post
I'm wonderin' too. I've got to replace almost new ones on the 350 in my Chevelle cuz they're leakin' already. Sure would like some that I don't have to worry about for a while.
56 Studebaker 2 dr Wagon
66 Chevelle 2 dr 4 speed
71 C30 Longhorn
86 Monte Carlo SS
96 Tahoe
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 05-01-2002, 05:09 PM   #4
Desert Rat
Desert Rat's Avatar
Post
i use the Felpro cork(or whatever comes in a overhaul set),just tighten evenly and dont over tighten.Sometimes i buy rubber-dont really matter to me.but when it comes to more critical i prefer good stuff no .099 pan gaskets,or real main seals,if its a pain in the ass to rplace i buy the better stuff.i wont use cheapy gasket sets off brands,i always stick to FelPro.
Desert Rat is offline   Reply With Quote
Old 05-01-2002, 05:09 PM   #5
69 longhorn
Post
Go for the felpro thick set,like the other longhorn dude said......no trouble......69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-01-2002, 05:32 PM   #6
neonlarry
neonlarry's Avatar
Post
Are those the $34.99 ones with the metal inserts, or the regular Fel Pro ones?
Old 05-01-2002, 05:36 PM   #7
69 longhorn
Post
No, I havent used the metal insert gaskets.they should be 7/32 thick. I prefer the neoprene impregnated cork.....dont like rubber gaskets........69
Old 05-01-2002, 05:45 PM   #8
COBALT
COBALT's Avatar
Post
I use whatever NAPA has over the counter for sb Chevy (cork). I clean the head with some scotch brite and some brake cleaner, and then I tack the gasket to the cover (but not to the head). Then I just tighten evenly with some hold-downs.
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-01-2002, 06:01 PM   #9
BadAzz70PU
Long Lost Member
Post
I highly recommend the metal insert cork gaskets, they seal great and you dont have to worry about them sliding on chrome or aluminum valve covers (which is a common problem). They can also be reused very easily.
Tony
1970 C10 LWB
-Worked 350
-Dropped 3/6
-Tangier Orange Paint
Visit my Web Site: www.low70.com
College student at Clemson (SC)
Home in Langhorne Pa
Instant message me on AIM at MilkMe131
GOD BLESS AMERICA
Tony
1970 C10 LWB
-14.09 @ 96mph
Web Site
1995 Eclipse GSX
-15.46 @ 88mph (stock, not for long)
BadAzz70PU is offline   Reply With Quote
Old 05-01-2002, 07:05 PM   #10
cali_surfer
cali_surfer's Avatar
Post
I use the Fel-Pro thick cork gaskets and use gasket adhesive to secure them to my aluminum covers (not to the head surface). My motor is leak-free!
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
Old 05-01-2002, 08:38 PM   #11
junkyardjohn
junkyardjohn's Avatar
Thumbs up
I ALWAYS USE FELPRO RUBBER GASKETS (ABOUT $11)& GLUE THEM TO THE VALVE COVERS WITH 3M WEATHERSTRIP ADHESIVE. THIS IS THE BEST SEAL I'VE COME UP WITH.TRY IT & I BET YOU DON'T USE ANYTHING ELSE --- EVER --
junkyardjohn
http://community.webshots.com/user/junkyardjohn
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-02-2002, 12:58 AM   #12
BUXMAN66
go bucks!
Post
i used the mr.gasket ultra-seals on mine.i've pulled the v.c.'s off different times and never had to worry 'bout it. has a high temp. plastic inner core surrounded by neoprene outer layer. can reuse over and over.nice thing also is that they never lose shape or thickness no matter how many times you take 'em off.
'68 swb 350/350 w/edelbrock total performance-performer pkg.ceramic headers,2.5" delta-flow 40 series flowmstrs.restored guage dash,interior,pioneer shaft-style stereo w/advent 300w 3way 6x9's,lift-up shock mount tonneau cover.drums w/6 lug alum. wheels w/knock-off's.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
