Old 09-25-2007, 01:37 AM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Lost My Keys!
So heres the situation, I need to "steal" my own truck, my 75 chevy has been sittin in the field for a long time and i lost the keys and i need to unlock the steering wheel so we can tow it home. Some PO long before i had the truck welded the steering wheel to the shaft because the threads were stripped. It has a non tilt, that i want to change anyhow, ive heard that you can smash the left side of the collumn and release the lock pin, does this really work?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 09-25-2007, 05:11 AM   #2
Yankeelights
Yankeelights's Avatar
Re: Lost My Keys!
It might be easier to replace the whole column ... no smashing involved.
Yankeelights is offline   Reply With Quote
Old 09-25-2007, 11:02 AM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Lost My Keys!
If the steering wheel is locked into positon, why don't you just unbolt the steering column shaft from the steering gear. At least then you can manhandle it to a trailer, get it home and swap out the column with the tilt unit you found. At least that way, you aren't smashing the column.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 09-25-2007, 11:45 AM   #4
Blue85
Oilfield Trash
Blue85's Avatar
Re: Lost My Keys!
I could do that, but i like smashing things lol.
87 Chev 3+3 4x4
Old 09-25-2007, 01:35 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
Re: Lost My Keys!
I would not recommend the smashing either.
Pyrotechnic is offline   Reply With Quote
Old 09-25-2007, 02:42 PM   #6
84_chevrolet
Truck CRAZY!
84_chevrolet's Avatar
Re: Lost My Keys!
If you are just wanting to move it you and a buddy can grab ahold of the steering wheel, twist it, and break the lock inside so that u can move it.
84 Chevrolet stepside, 350 with .60 over pistons, aluminum zr1 heads, doug herbert .500 lift cam, 1.6 roller rockers, elderbrock intake with a 600 holley carb, mated to a 700r4, 208t-case and 4-11 gears,33 goodyear wrangler mtrs
84_chevrolet is offline   Reply With Quote
