Old 09-25-2007, 02:18 AM   #1
pat
pat's Avatar
Question 2" lift with blocks?
My new tires rub a little bit sometimes. I was wondering if I could go the cheap route and lift the front and back both 2 inches with blocks. I made lowering blocks for my 68, but Im pretty sure I can get 2" blocks with bolts that are angled to correct the angle for about $20 a set. Anything wrong with this? I dont have too much $$$ to buy a good lift.
It would be for my 89 GMC Jimmy fullsize.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 09-25-2007, 03:37 AM   #2
earl87gta
earl87gta's Avatar
Re: 2" lift with blocks?
I would get a set of 50 add a leaf springs for the front its abad Idea to use blocks on the front they tend to move when steering. for the back that would be ok. there I s a 1in zero rate pring you can run on the front its like a block that bolts to the spring pack like a spring. there are sevral places that sell them DIY4x4 and ORD are the most popular.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
