Old 09-25-2007, 01:46 PM   #1
ctouchet
ctouchet's Avatar
TH350 Kick Down Cable
Where does it hook up to on the transmission ( any pictures) I dont see a place to hook it too.
2012 F150 SuperCrew
2011 GMC 1500 (COMPANY TRUCK)
1982 Chevy Blazer 2WD (Work in Progress)
ctouchet is offline   Reply With Quote
Old 09-25-2007, 04:09 PM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: TH350 Kick Down Cable
IIRC it goes in the tranny on the passenger side behind the bellhousing and before the dipstick - can't take a pic of it now tho, still (bored) at work, lol
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 09-27-2007, 03:24 PM   #3
ctouchet
ctouchet's Avatar
any one have a picture
2012 F150 SuperCrew
Old 09-27-2007, 06:32 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
if you don't have the cable connected now, or a part of another cable, then you will have to pull the oil pan and connect the new cable to the linkage.
piecesparts is offline   Reply With Quote
Old 09-27-2007, 07:07 PM   #5
75shortysocal
350+dual flows= fun :)
75shortysocal's Avatar
heres a pic
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!!
SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!!
75shortysocal is offline   Reply With Quote
Old 09-27-2007, 07:35 PM   #6
xtreme80
Wishin' I had more money!
xtreme80's Avatar
I think he needs a pic from underneath the truck on the tranny itself. Let me go snap a pic real quick, if my batteries are still good that is.
xtreme80 is offline   Reply With Quote
Old 09-27-2007, 07:40 PM   #7
xtreme80
xtreme80's Avatar
Best pictures I got. Turns out my truck is too low to crawl completely under it
And the exhaust is too hot right now and Im not about to burn the crap out of my arm to try to get a better one.
Old 09-27-2007, 11:28 PM   #8
Ivan D.
Ivan D.'s Avatar
Darn, completely forgot about that thread, sorry man - here ya go:
Old 09-27-2007, 11:32 PM   #9
Ivan D.
Ivan D.'s Avatar
As you can see the cable goes in the tranny case just a few inches before and below the cooling lines fittings, it normally goes up behind the engine but mine is disconnected, hence the weird bend towards the frame and away from the engine.
Old 09-28-2007, 08:02 AM   #10
ctouchet
ctouchet's Avatar
thanks for the pictures
2012 F150 SuperCrew
Old 09-28-2007, 11:47 AM   #11
impala_631
:( BYEBYE :(
impala_631's Avatar
is that a pretty strait foward job?
impala_631 is offline   Reply With Quote
Old 09-28-2007, 11:54 AM   #12
Ivan D.
Ivan D.'s Avatar
well if the pan ain't got no drain plug (and most don't) it can get a real messy job, haven't done it to the truck yet but on my Lincoln when I'm about to drop the tranny pan I first disconnect the return line from the ATF cooler up front and let the tranny pump itself dry - there's still some ATF left in the pan afterwards, but still not even close to the ungodly amounts that normally live there - less ATF in pan, less spill on the floor, less complaints from the lady
Old 09-28-2007, 12:02 PM   #13
impala_631
:( BYEBYE :(
impala_631's Avatar
yeah, ive dropped pans before for filter changes and a hurst shifter, i know they can get messy, i just didnt know how hard the cable hook up was, or how easy/hard it was to access
Old 09-28-2007, 01:30 PM   #14
Ivan D.
Ivan D.'s Avatar
There was a picture of that thing inside the tranny somewhere here me thinks, do a search and include all the sub-forums.
