09-25-2007, 06:39 PM | #1 |
1971 rear end housing length vs. 1968
Hey guys,
I was wondering if my 1971 rear end is the same length as a 1967 or 1968 rear end? Someone told me that a 1967 rear end is 1.5" narrower than a 1971housing, is this true? |
09-25-2007, 06:48 PM | #2 | |
Re: 1971 rear end housing length vs. 1968
The earlier 60's thru mid-year 70-model rear housings are narrower than the late 70 thru 72-model housing. The 1.5" sounds about right. Basically, if it has 6-lug axles (from the factory), it's likely the narrow housing; if it came w/5-lug axles (factory), it's the wider housing.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-25-2007 at 06:49 PM. |
09-29-2007, 02:46 PM | #3 |
Too Many Clubs Club
I just measured this the other day to help out a board member in this thread.
My '68 rear (the one you helped load in my truck SCOTI) is 62" from wheel to wheel. My '72 rear measures 63.5" wheel to wheel...exactly 1.5" wider.
How I installed my air bags... |
10-21-2007, 07:50 AM | #4 |
so does that mean that you cant swap 5 bolt axles out of a 71 and put them in a 68 6 bolt factory rearend?
10-21-2007, 05:25 PM | #5 |
:( BYEBYE :(
kool
