09-25-2007, 07:05 PM | #1 |
Yet another power disc brake conversion thread (questions)
Hi guys, I just bought a 68 stepside (short bed) not long ago, and I'm doing some research into converting the 4 wheel drum brakes (manual) into 4 wheel disc brakes (power assisted). I've tried search, but couldn't find satisfactory answers to this, so here goes:
1) Since I have non-power brakes right now, will the pedal assembly and pushrod from the pedal to the brake booster be good? Do I need to buy a new one? 2) I would have to buy either a 9" single diaphragm or 8" dual diaphragm brake booster, right? Any recommendations on these? Any good aftermarket units? Should I just go with a new stock replacement one? 3) Master Cylinder choice: I would really like to go with an aftermarket one, namely I have my eyes on a Wilwood MC, but it has a choice for 3 different bore sizes, 7/8", 1", 1 1/8" ( http://www.wilwood.com/Products/006-...TCMC/index.asp ). Would these fit? If so, which one to chose? 4) Brake conversion kits front/rear. There are plenty of kits out there for the conversions, any particular ones I should consider or avoid? Thanks a lot, Ovidiu |
09-25-2007, 07:55 PM | #2 |
That's right, it's Copper!!
Re: Yet another power disc brake conversion thread (questions)
Early Classic has the best front brake kit. Give Terry a call and ask him all these questions. 1-888-777-0395
09-25-2007, 08:19 PM | #3 |
#1 Pedal assembly is fine, you will need a new push rod.
#2 You will also need the power booster bracket and bell crank from these trucks. #3 I would use a GM disc\disc master along with a disc\disc proportioning valve.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-25-2007, 08:57 PM | #4 | |
I would still like to spring for the Willwood MC and prop. valve if I can make them work. |
09-25-2007, 10:42 PM | #5 |
Call Early Classic, they will fix you up with everything you need. The pushrod, brackets, etc. all come in the kit. I bet they can even fix you up with the rear system or send you to someone who can.
09-25-2007, 11:42 PM | #6 |
I don't know if the ECE kit has the bracket and bell crank, not shown in their kit picture. I think the only place to get one is probably off a power brake truck (and no they don't come with the booster) also the push rod will need to come off the same truck. As to the willwood master you will have to ask them if it will bolt up to which ever booster you are planning on using.
09-26-2007, 11:32 AM | #7 |
at brotherstrucks.com it appears that their boosters have the bracket and rods
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
09-26-2007, 12:37 PM | #8 |
The Early Classic kit that I have came with everything, brackets, pushrod, nuts, bolts, everything!!! Good people that want to help and not just sell stuff.
09-26-2007, 12:59 PM | #9 |
Mejor Que Nada
Yep ECE came with everything it also gives you instructions dealing with push rod. You have to drill a whole one inch higher in the pedal assembly if I remember correctly also you re use the rod to pedal adapter you currently have.
The only thing that separates "Dreams" from "Reality" is TIME and MONEY!!! |
09-26-2007, 01:34 PM | #10 |
I agree ECE is great but Ive been searching the internet lately and have found piecing things together are cheaper, check out kore3.com they have great deals but they do generally deal with c5 corvette brake conversions.
If your going with the wilwood buy the biggest bore possible its better to move more fluid then not move enough expecially when going to disc, even the stock gm stuff is 1" or larger
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 09-26-2007 at 01:35 PM. |
09-26-2007, 02:49 PM | #11 |
Allright, I'm gonna give ECE a call, sounds like I'm gonna be getting pretty much everything from them, minus possibly the MC and proportioning valve.
So should I go for the single diaphragm or dual diaphragm booster? Thanks a lot guys! |
