Old 09-25-2007, 08:40 PM   #1
muddpile
muddpile's Avatar
Front Driver Disc stuck?
Since I'm doing a full resto, I decided while I was at it, I'd replace the master cylinder. It leaked a little, and was so rusty you could hardly tell what it was. I bought one from the parts store, hung it on the firewall, hooked up the proportioning valve and brake lines, and bled the prop valve with the little screw on the front. I then bled the remaining brakes until clean new fluid came out (I basically flushed the system. Now, the problem is that the front drivers caliper is now clamped down tight, no movement. The other three brakes are fine, but that one is now stuck. Should I open the bleed screw and use a C-clamp on the piston to clean out more fluid from the caliper and see if that's the problem, or is there another thing that might be wrong? Thanks!
muddpile is offline   Reply With Quote
Old 09-25-2007, 08:45 PM   #2
ChevyC102007
ChevyC102007's Avatar
Re: Front Driver Disc stuck?
Sounds to me like you might have rust or dirt inside the caliper bore itself, that will cause the caliper to freeze in place. IMHO Id go ahead and rebuild both calipers on the truck, its hard to tell just how much crap is still in those calipers even with new fluid in them. Just my .02
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 09-25-2007, 09:03 PM   #3
crazy longhorn
Fabricate till you "puke"
Open the bleeder, & see if that frees up the wheel, You could have a collapsed hose. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-25-2007, 09:30 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
crazy is right, if the brake frees up when you opent he bleeder, then it's a hose that failed internally.
However, my money is on rust and crap in the sylinder.
While rebuilding them is cheap and not all that complicated, I think I'd just replace it with a new one.
Old 09-25-2007, 10:03 PM   #5
DREAMS OF A 67
Step Brother
DREAMS OF A 67's Avatar
I cant find kits for the calipers any more. where do you get them?
DREAMS OF A 67 is offline   Reply With Quote
Old 09-26-2007, 12:56 AM   #6
muddpile
muddpile's Avatar
Thanks guys! I'll give it the test tomorrow.
