09-25-2007, 10:19 PM | #1 |
65 - Chevy C10
wheel cylinder part 2
So I had to special order my new wheel cylinders. I got them and comparing the old with the new and the new ones are slightly larger. I bolted them in and they seem to fit. They are a bit snug with the rubber boot against the backing plate a bit.
Do you think this is an issue? Anyone have a part number to suggest? This is what I have Raymold (Raybestos) Part Number: 2037026/right, 2037025/left Part Number: 2037026 Inlet Thread Size: 7/16-20 IN Bore Diameter: 1 1/8 IN Material Type: Cast Iron Grade: STANDARD Sub Brand: RAYMOLD Type: Wheel Cylinders Last edited by salazar44; 09-25-2007 at 10:20 PM. |
09-25-2007, 11:15 PM | #2 |
Re: wheel cylinder part 2
i'm getting ready to replace mine as well, but noticed the old one are close to the backing plate as well, what size socket was used to remove them
(assuming the front ones) thx |
09-25-2007, 11:26 PM | #3 |
65 - Chevy C10
I just used a big adjustable wrench. They came out pretty easily. I guess I was lucky my threads were smooth and silky!
Let me know what brand and part number you get please! and also if the rubber boot is tight up against the backing plate. Thanks. |
09-26-2007, 04:32 AM | #4 |
i got my rear wheel cylinders at autozone. i dont have the part number anymore. i got everything to replace all the rear brake parts at autozone. just thought id let yall know.
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
