Old 09-26-2007, 12:21 AM   #1
bigbluthng
bigbluthng's Avatar
bagged ride as a daily driver
how do you like it? what would you do differant. what issues do you encounter? i'm thinking of using the blazer as a daily driver once i get her all bolted up and ready to go again. i only have a 5 mile in town commute and it hardly rains here so that's not a concern.
bigbluthng is offline   Reply With Quote
Old 09-26-2007, 11:50 AM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: bagged ride as a daily driver
I drive mine daily. Just need to tuck the exhaust up tighter. I tend to ride as low as possible so there's the occasional scrapage... But the collector flanges are still holdin on I also have a digital system that makes it more convenient I suppose. I think the most important thing for a DD is to be sure it can still roll freely when aired out (mine cannot at the moment )
Frizzle Fry is offline   Reply With Quote
Old 09-26-2007, 12:26 PM   #3
abadsvt
abadsvt's Avatar
I agree with what Frizzle said. I used to have a 65 chevelle that was bagged and i drove it alot. Almost a daily driver and i popped 2 air bags and the front would scrap when they popped. If you are going to drive it daily i would recommend to have it setup so if a bag pops you can still drive it or at least drive it off the road. I would also recommend getting a digital air gauge so that way you can drive the truck at the same amount of pressure so you save your tires. Besides that i loved it. I would definately do another bagged driver!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 09-26-2007, 02:14 PM   #4
bodydropped
ive drove mine about 4k miles in around month and half mines a daily driver i dont lay all the way in the frt since we set it up on 17s and im still running my frt inner fenders but once i get 20s were tubing it
bodydropped is offline   Reply With Quote
Old 09-26-2007, 03:12 PM   #5
fastbagged68
fastbagged68's Avatar
Look into Accu Air Control System for a daily driver. The system will go to ride height when you start the car. It is based on suspension sensors and not air pressure.
fastbagged68 is offline   Reply With Quote
Old 09-26-2007, 05:53 PM   #6
edflores
no guages on mine. does fine. had a toyota bagged and bodydropped as a daily but it was on ball valves connected to a gauge so it was real easy to ride at desired height. my bagged ride was stranded once when an airline got loose and my tire rubbed it up till it blew. then i was stuck at home last week because i ran out of nitrogen. lame. but i keep a schrader valve and a few crecent wrenches in my truck in case i run out again.
edflores is offline   Reply With Quote
Old 09-27-2007, 11:01 AM   #7
Scott68-93-97
Scott68-93-97's Avatar
I agree I ripped my exhaust right off the manifold when the original crossover pipe still hung low on a man hole cover, I had my exhaust guy tuck it up tighter to the motor and all is well drove it daily for years until I tore it apart to change a few things
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 10-04-2007, 12:12 AM   #8
bigtruck81
i came across my install and service manuals for AccuAir today while i was at the shop, and wondered how it would work on something other than a motorhome (what we use them on) apparently they're pretty decent. neat and easy to use systems for sure.
bigtruck81 is offline   Reply With Quote
Old 10-04-2007, 02:23 PM   #9
impala_631
:( BYEBYE :(
impala_631's Avatar
just make shure its a quality setup with a good install and dont abuse it and you will be fine
impala_631 is offline   Reply With Quote
Old 10-04-2007, 04:50 PM   #10
bodydropped
ive put 5k on mine since its been bagged and thats been about 2 months ago
Old 10-04-2007, 11:02 PM   #11
ZBS 64
ZBS 64's Avatar
Driven daily here in the great north west
ZBS 64 is offline   Reply With Quote
