Old 09-26-2007, 07:09 AM   #1
earl87gta
earl87gta's Avatar
1 ton chassis under the burb
I was looking at my pile of parts for the burb and got thinking it is going to have a 1ton drive train why not make it a true 1 ton and shorten a 1ton chassis down to fit the burb. What do you guys think?
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-26-2007, 10:46 AM   #2
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
Re: 1 ton chassis under the burb
I would'nt mess with it. I don't think a frame swap would be worth the time, unless you have major cancer. I'd just weld in X braces if you are looking for less twist.
hilbilly is offline   Reply With Quote
Old 09-26-2007, 10:50 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
What year is the 1 ton chassis and what is the intended use of the Burb?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-26-2007, 01:43 PM   #4
earl87gta
earl87gta's Avatar
I think its a 72. Poor burb will get abused Im sure. This thing has a lot of waight to throw around and will be used for camping and as a recovery vehical for a buggy when I get around to building one. i was thinking if the 6.2 ever goes up in smoke that Im puting in it the next step will be a 6bt so this would give me a better frame for when that day comes. The burb is coming off the frame nomatter what so every thing can be blasted down and painted plus it will be easier to figure out the new drive line with the body off I have to mount the divirced 205 and the NV 4500 in it so I want to make all the new cross members with the body off.
Earl
Old 09-27-2007, 06:14 AM   #5
vtblazer
vtblazer's Avatar
How much different is the one ton frame your looking at using?
Alot beefier?
You said 'cut it down' , aren't burb and truck wheelbases the same already?
vtblazer is offline   Reply With Quote
Old 09-27-2007, 06:36 AM   #6
earl87gta
earl87gta's Avatar
The 1 ton frame is 8in tall instead of 6 and the 1 tons have a 133 wheel base and the burb and LWB trucks have a 127. The wheel base is probly close enough I could work with it. I have the axles set back 1in with 0 rates any way and moved forward 1in in the front.
Earl
Old 09-27-2007, 10:13 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Thanks for the additional information. I like the idea of you using the 1 ton frame with the Diesel engine. I say go for it and be sure to document the project as you go!
Old 09-27-2007, 10:15 AM   #8
earl87gta
earl87gta's Avatar
I dont think it will be a hole lot more work and if I do it I will truly be able to say its a 1ton burb.
Earl
Old 09-27-2007, 02:07 PM   #9
vtblazer
vtblazer's Avatar
since your tearing into the frame, may as well go true one ton.
Old 10-03-2007, 01:53 PM   #10
va_tlc
va_tlc's Avatar
earl you doing this to the red blazer? if so thats gonna be mean.. take plenty pics fer us
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 10-04-2007, 02:25 AM   #11
earl87gta
earl87gta's Avatar
No going under the 68 burb. my wife said I need to build a better family truck that the blazer is to hard to load kids in and she doesnt like not having a top. so Im building a burb now so we can have a back door.
Earl
Old 10-07-2007, 02:47 PM   #12
1969 GMC
1969 GMC's Avatar
Keep the K30 frame around anyway. They have a thicker cross section than 3/4 or 1/2 ton frames, in case you ever build another buggy or something else.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-08-2007, 12:26 AM   #13
earl87gta
earl87gta's Avatar
Its a c30 fram that Im going to have to convert to a k30. I just want the hevy duty frame for the bazer.
Earl
