09-26-2007, 01:17 PM | #1 |
spindles
ok guys heres my first question on the forum. I have a 72 half ton front end to convert my 67 to disc brakes. but I want to keep my truck 6 lug ( nice rims) so If i order the 6 lug rotors from a supplier. (they are not 4x4 rotors but 2wd rotors converted i guess.) will they fit on 1972 spindles? In other words, are 72 spindles different than 73 and up? thanks in advance.
1967custom |
09-26-2007, 02:54 PM | #2 |
Re: spindles
Michael, welcome to the board. Give Early Classic Enterprises a call. They should be able to answer your question alot better. I don't know what you paid for the 72 front end you have now, but it may be cheaper to order a new 6 lug setup from them. The 72 setup uses different ball joints, tie rods, and drag link. You can order spindles from ECE with 6 lug rotors that use all the original 67 steering linkage and ball joints.
www.earlyclassic.com
09-26-2007, 03:06 PM | #3 |
Re: spindles
Also GMCPauls has great prices on their kits....
1997 GMC Sierra Ext 1965 Mustang |
09-26-2007, 03:49 PM | #4 |
Re: spindles
That what I needed. thank you. I got the setup for free but I think replacing the spindle with a new one from ece would be the way to go since I`m not doing serious mods to the suspension. Thanks again guys
1967custom |
09-26-2007, 06:31 PM | #5 |
Re: spindles
What I'm doing is putting an 84 suspension on mine, then getting the 6 lug rotor kit from GMCPauls........
