09-26-2007, 02:08 PM | #1 |
Sophomore Member
how do you remove ziebarting/undercoating
my truck had the ziebarting/undercoating, whatever crap sprayed on it when it was new. it saved a lot, but it's on the underside of hood, inner fenders, everywhere. does anyone know of an easy way to get it off?
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
09-26-2007, 02:20 PM | #2 |
Farm Truck
Re: how do you remove ziebarting/undercoating
I'm in the process of doing that now, paint stripper and a gasket scrapper.
I bought the aerosal paint stripper. Spray it on and scrap it off. Then I DA sanded the left over. When it's thin it sands right off.
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
09-26-2007, 02:24 PM | #3 |
I will have to do this in the future also. On some of the parts that I have cleaned on my truck a solvent like laqure(SP) thininer, removed it with some work.
68 Chevy C-10 custom, 350,4bbl, serp belt swap, th400, 5 lug disk conversion, added honda seats and factory tach. 71 Gremlin X, 360, t-5, 8 3/4 rear, and dodge dakota seats. 82 Spirit, 4.0,ax-15, 8.8 rear and sti bucket seats |
09-26-2007, 02:31 PM | #4 |
I would think a higher pressure steam cleaner may get it off......either way a fricken messy job!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
09-26-2007, 02:41 PM | #5 |
what about aircraft stripper?
1967custom |
09-26-2007, 02:57 PM | #6 |
auto paint supply stores have a product called underoff eastwood carries it 2
09-26-2007, 05:10 PM | #7 |
Official Site Guitar Shredder
Lots of Elbow Grease lol, i just did all this on my PROJECT. first i used a small propane torch, it works well. i just ran the torch on the undercoating. and scrapped it off, i then followed with paint remover. then wire burshed the whole frame, and wet sanded the frame with laquer thinner as my wet.... worked great...........
09-26-2007, 11:06 PM | #8 |
i had that crap all over my engine compartment and had a baaad fuel leak and it washed it all off... down to the base paint
09-26-2007, 11:31 PM | #9 |
I used a knot style wire wheel on the end of a 4" angle grinder, and it took it right off. Very quickly too.
09-26-2007, 11:44 PM | #10 |
Saving 1 truck at a time!
Get a cheap heat gun from Harbor Freight and a putty knife. After you have removed 99% with that use a Scotch Brite pad and cheap mineral spirits to revmove the final film. Very quick and easy and the cleanest way...I have tried them all and always go back to this method.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
