09-26-2007, 03:49 PM | #1 |
Aftermarket rearend and traction system
My truck is a 1966 Custom shortbed that I love. I'm in the planning stages for a switch next year to a big block Ultrastreet crate motor with about 750 horsepower from Shafiroff. I want to replace my current rear suspension with something that can handle the horsepower, give me straight line traction, and can still corner. I plan to run the widest tires I can fit under it but not tub it at this point.
What differential and suspension combination would you recommend if money was no object? The more of a system it is, the better since I want it all to work together and fit together well. I look forward to your thoughts. |
09-26-2007, 10:57 PM | #2 |
Re: Aftermarket rearend and traction system
corvette irs.
http://www.hotrod.com/techarticles/1...dup/index.html |
09-27-2007, 02:43 AM | #3 |
chevy only
2001 s-10 4x4 rear end 8 1/2 ring gear pos /plus disc, stronger people say than the ford 9" and fits slick only 500 bucs
09-27-2007, 06:09 PM | #4 |
Dana 60. Go with a 4 link or boxed trailing arms if moneys tight. I've not heard of a 8.5 rear being stronger than a 9" but I know there tough. Check out HTR hotrodstohell web site.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by shortbed70; 09-27-2007 at 06:09 PM. |
09-27-2007, 11:08 PM | #5 |
60-66 Nut
Personally I'd go with a Dana 60 and a 4 link either straight or triangulated. I'm in the process of installing a triangulated 4 bar from Art Morrison in a '67 swb. I would suggest contacting Art Morrison, everyone I've talked with there were very nice to talk with and helpful. I've used their parts on a couple of projects and it's all top quality stuff. You could even go with a complete rear frame clip from AME.
http://www.artmorrison.com
10-09-2007, 03:28 PM | #6 |
Thanks for the advice. I thought the Corvette article was interesting. I think the Dana 60 and the triangulated 4 link sounds a little less complicated though. Now I need to find a good suspension shop willing to do the swap. Thanks again.
10-09-2007, 04:32 PM | #7 |
Truck and auto performance nut
if you want to stay GM, the '06-'08 TrailBlazer SS has a 9.5" rear end and comes standard with limited slip and 4.10 gears....and since it comes on a 4600lb truck with 400 ft. lbs. of torque....it might be as tuff as a Ford 9"?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
