Old 05-02-2002, 12:36 AM   #1
BUXMAN66
go bucks!
Post pwr.steering ques.???
wonderin' what causes the pwr.steering to work sporadically when engine is not revving.i've noticed it several times b-4, that when i go to back down my driveway,and initally the wheel is turned to line up my rear end w/ the driveway,the steering makes a noise like it's really straining.once you get some rpm's the steering is responsive and the straing noise goes away.makes you almost think the pump is low on fluid, but the level is perfect,both at cold and hot temp's.whats making the pwr. steering strain so much unless it has sufficient rpm's?? anyone?
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 05-02-2002, 01:28 AM   #2
CoryM
Post
If the belt is tight without seeing it I would say your pump is on its way out. What fluid you use? I see lots of guys run ATF, dunno why, not like its any cheaper than P/S fluid .
Good Luck
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 05-02-2002, 01:48 AM   #3
COBALT
COBALT's Avatar
Post
My p/s pump is about to go. It makes a low-pitch hum when I'm stopped at lights, but if I turn the wheel to the right a bit (under load) the sound stops.
Also, if I make a sharp right turn and hold the wheel to the right I hear this small thudding noise like something is tapping against the inside of the engine compartment...
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
